BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
09-13-2010, 08:34 | #16 (permalink) | |
Freak Poster Join Date: Mar 2005
Member: 126801 Status: Offline Thanks Meter: 23 | Quote:
maybe you reheat the parts but not enough just reheat the IC and all the small componets around the connector or resolder every pin of any parts it will work 99.9%. many times i used this method and never been changed any ic and surely it works..... | |
09-13-2010, 09:10 | #17 (permalink) | |
if you are sure that the trackpad is working, from the trackpad connector there is small parts around on it just resolder it. and it will work again. | |
The Following 2 Users Say Thank You to windelas For This Useful Post: |
11-20-2010, 10:44 | #19 (permalink) |
Junior Member Join Date: Mar 2007
Member: 463820 Status: Offline Thanks Meter: 2 | i had same prob even after change of trackpad worked for some time n stoped i removed d trackpad n put wd40 on d connecter ic n components near by looked like a moisture prob 2me but d phone came back after 2month did d same n gave it back |
04-12-2011, 21:52 | #21 (permalink) |
Freak Poster Join Date: Mar 2009 Location: uk
Member: 996052 Status: Offline Thanks Meter: 35 | [QUOTE=asghar_khan870;6321877]Hello i also want a picture of that ic for sensor... 8520[/QUOTE Hello people I can give you the moddel number of the tracker pad ic it might help you yeo8 t10bk ARZN I fix more then 20 phones it work every time good luck to all of you I will try to upload picture for you lot |
04-13-2011, 00:34 | #24 (permalink) |
Member: 996052 Status: Offline Thanks Meter: 35 | http://www.4shared.com/photo/_aPMqm87/IMG_0172.html this is the link for blackberry 8520 key pad and tracker pad ic if you like my post just press thanks |
The Following 2 Users Say Thank You to i am the master For This Useful Post: |
blackberry 8520 drivers problem... | ZIYAAD STRYKER | BlackBerry (RIM) | 5 | 05-06-2013 09:58 |
bb 8520 mouse problem | arlbie | BlackBerry (RIM) | 30 | 09-01-2012 09:11 |
BB 8520 Big problem (Answered) | ericnite101 | MXKEY Blackberry Flasher and Unlocker (by Alim Hape) | 8 | 03-01-2010 01:10 |
Blackberry 8900 Curve, Blackberry 8520 unlock problem [MEP still not in server] | pitikor | PolarBox 3 | 2 | 12-30-2009 03:45 |
blackberry 8520 unlock problem | patric | FuriousGold | 7 | 11-16-2009 23:09 |
