BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
06-20-2011, 06:01 | #2 (permalink) |
No Life Poster Join Date: Apr 2007 Location: Motalib Plaza,Dhaka,Bangladesh Age: 39
Member: 485407 Status: Offline Sonork: 100.1580486 Thanks Meter: 183 | Faced same problem but no solution Yet !! In my opinion it's software problem but we don't have such tool like mml for this phone. |
06-20-2011, 17:18 | #3 (permalink) |
Freak Poster Join Date: Apr 2010 Location: Indonesia
Member: 1290467 Status: Offline Thanks Meter: 180 | I thinks this hardware problem sir... tested by me SOLUTION FOR GEMINI 8520 LOADING 75% AND STUCK by Tiroid Flasher From INDONESIA br IyhAN bOy |
The Following User Says Thank You to iyhan boy For This Useful Post: |
06-20-2011, 19:03 | #6 (permalink) |
No Life Poster Join Date: Apr 2011 Location: ranchi jharkhand
Member: 1564275 Status: Offline Sonork: badal ranchi Thanks Meter: 120 | flash your handset bro 100% tested solution...............go here for solution........http://forum.gsmhosting.com/vbb/f489...sy-way-895988/ |
11-20-2011, 20:15 | #10 (permalink) |
Junior Member Join Date: Nov 2011
Member: 1691784 Status: Offline Thanks Meter: 0 | I have a Blackberry curve 8520 IMEI 354908048641712 which is locked to Orange and would like to know if anyone can help me unlock it Also if any instructions needed i would appreciate those as well Thanks in anticipation !!!!!! |
11-23-2011, 16:43 | #12 (permalink) |
Junior Member Join Date: Jul 2008
Member: 815456 Status: Offline Thanks Meter: 4 | What has worked for me on 7 8520 units is to make sure the battery is full, then open blackberry apploader and click next, put the battery in the phone and plug it into the usb cable as QUICK as possible, as soon as you see USB PIN Unknown click next immediately, this is important because you catch the phone in it's startup mode, if you wait until it says USB PIN 22b9302c for example it will be too late. Once you have done this all you have to do is wait for the apploader to do the work. This has worked for me on at least 7 units and I would recommend you to try this before going to hardware solution, I must give credit for this solution to Crackberry.com. PS: this solution can take up to 30 minutes so be patient. |
05-12-2012, 13:11 | #13 (permalink) |
Insane Poster Join Date: Nov 2004 Location: Barcelona, Spain Age: 47
Member: 93011 Status: Offline Sonork: 1580222 sorin_mirza Thanks Meter: 12 | working Thanks iyhan boy Changed IC and now is working |
The Following User Says Thank You to mirza For This Useful Post: |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
