Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > BlackBerry (RIM)
BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs.
Old 11-03-2010, 18:29   #1 (permalink)
Member: 3204
8520 update problem
Hi
i have one 8520 and cant power on, wenn i put battery phone power on with white lcd
wenn connect to udb and run loader.exe, found phone on usb, and ask for password
i dont know password
how to repair this bb?
best regards
Old 11-03-2010, 19:12   #2 (permalink)
Member: 1406087
Follow the link below, sounds like the same problem...
BlackBerry 9000 Pasword
gpz900ra7.
The Following User Says Thank You to gpz900ra7 For This Useful Post:
Old 11-04-2010, 11:19   #3 (permalink)
Member: 3204
gpz900ra7.
yes, bb is wiped and now complwtw stage1, than got to stage 2, phone power up with blank white lcd and always connecting to JVM and error aplication loader was unable to connect with your device
Old 11-04-2010, 13:51   #4 (permalink)
Member: 1406087
You now need to download, and install a small program called "JL cmder"
JL_Cmder Javaloader Utility
This will wipe the phone completely, enabling you to reinstall a fresh copy of your Operating System on to your phone.
Make sure to get the latest OS for your handset, and REMOVE the file named "Vendor.xml" from the "Apploader" folder.
If you have any difficulties, I'll gladly help you out.
Best of luck.
gpz900ra7.
Old 11-04-2010, 15:43   #5 (permalink)
Member: 3204
Best of luck.
gpz900ra7.
ok
after use jl_cmder bb is dead totally
ven put battery bb is dead
wenn connect to usb i have white lcd (no error on screen)
run loader and after step 2 again error "aplication loader....."
please step by step how repair
with battery or without or something else?
i am newbie in bb world
Old 11-04-2010, 17:43   #6 (permalink)
Member: 1406087
Done a bit more digging, and came across this, follow the link.....
JVM Error 102 -- BEFORE YOU WIPE YOUR SYSTEM -- - BlackBerry Support Community Forums
Have a read of the link included in one of the posts.
gpz900ra7
Old 11-05-2010, 10:27   #7 (permalink)
Member: 3204
Originally Posted by swand View Post
ok
i have error
wenn i type 2. log is empty and error is cant connect com port
hoe to read? power on phone with battery and plugged usb cable or only cable without battery?
Old 11-05-2010, 11:19   #8 (permalink)
Member: 1406087
Hi, this is a tricky one,
You need the battery in the phone at all times.
Does your phone show anything on the screen apart from just a white background?
Is your phone recognised by the computer when you plug the USB cable in?
Have you got the software CD that came with your phone, as this has the USB drivers on it?
If you have got the disc, remove all traces of the software from your computer, and then do a new install from the BlackBerry CD, that will put all of the software needed on your computer.
We cannot do anything until your computer sees your phone, then we can go ahead and start from the begining again.
Don't worry if this just a software problem, we will fix it, .
gpz900ra7.
Old 11-06-2010, 12:46   #9 (permalink)
Member: 3204
gpz900ra7.
only blank screen
wenn connect and red light blink, computer reckognize bb at usb and wenn red light off and come white screen computer reckognize uknown device
Old 11-06-2010, 18:16   #10 (permalink)
Member: 1406087
Is the phone seen as "Unknown device" in LOADER?
If so, install battery into the phone just as the message appears, then you may have a chance at installing the software.
gpz900ra7.
Old 11-08-2010, 14:09   #11 (permalink)
nykocam's Avatar
Member: 67494
gpz900ra7.
phone absolutely not recognized,nothingh at all,i try the bbsak now
Sim card sleep mode problem with 6130 ratzfatz Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 05-22-2012 11:13
GId1 problem old_man Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 10-18-2006 15:21
6110 5.47 sw unlock problem gsms Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 11-21-1999 18:43
6150 Lock Problem Zeljko Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 09-11-1999 17:39
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 07-16-1999 00:44
Page generated in 0.51264 seconds with 11 queries
