Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > BlackBerry (RIM)
BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs.
Old 12-09-2008, 05:14   #1 (permalink)
Member: 61810
Sonork: 100.1605340
Thanks Meter: 136
8700 cant update using desktop manager after mfi multiloader
what seems to be the problem with this phone?
i succesfully unlocked 8100 units but not on this phone.
i cant upgrade via blackberry desktop manager.
i already succesfully patched with mfi multiloader.
phone status is now white screen(no application installed)
latest 8700 4.5 firmware already installed in my pc.
screenshot:
Old 12-09-2008, 05:19   #2 (permalink)
.:SUBRATA:.'s Avatar
Member: 319447
Thanks Meter: 4,945
Remove vendor.xml From C:\Program Files\Common Files\Research In Motion\
Then Open desktop manager again.
Old 12-09-2008, 05:20   #3 (permalink)
Moderate's Avatar
Member: 232566
Thanks Meter: 148
Hello,
it is always better to read Sticky and F.A.Q or search is the even better option before asking,check out this link.
No Software Update is required for your device ((Solution here))
Regards,
Old 12-09-2008, 05:21   #4 (permalink)
Member: 180833
Sonork: 100.1578281
Thanks Meter: 215
Delete the vendor.xml file located in c:\program files\common files\research in motion\apploader
Old 12-09-2008, 05:34   #5 (permalink)
Member: 61810
Sonork: 100.1605340
Thanks Meter: 136
unit is still white screen now..
with display message (no application linked)
Old 12-09-2008, 05:52   #6 (permalink)
Member: 918950
Apparently my PIN has been locked. Now I have an Unlocked device with a locked PIN.
Old 12-09-2008, 05:57   #7 (permalink)
Member: 61810
Sonork: 100.1605340
Thanks Meter: 136
get this error when forced start
no upgrade happened
Old 12-09-2008, 06:05   #8 (permalink)
reimon23's Avatar
Member: 268175
Thanks Meter: 197
did you try to click the "option"?
then some applications appear to select?
Old 12-09-2008, 06:07   #9 (permalink)
Member: 61810
Sonork: 100.1605340
Thanks Meter: 136
no application designed for your device were found.
Old 12-09-2008, 07:36   #10 (permalink)
Member: 61810
Sonork: 100.1605340
Thanks Meter: 136
problem solved.. thanks to ramjan
Old 12-09-2008, 07:43   #11 (permalink)
Member: 564009
Thanks Meter: 4
sir can you post here..what is the solution regarding your problem for us to further understand blackberry unlocking
.::GPG Desktop Manager extreme DB Update::. GPG_SUPPORT Service Products News & Updates 0 03-29-2010 05:17
Blackberry 7130c Unlock using MFI restore without desktop manage nhey_killuah BlackBerry (RIM) 4 08-21-2009 18:17
Problem with Bold after mfi multiloader! big_gsm BlackBerry (RIM) 0 07-09-2009 13:31
how to use desktop manager to flash blackberry?? kaholukkk FuriousGold 1 05-20-2009 12:01
Page generated in 0.30812 seconds with 8 queries
