BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
02-20-2014, 13:59 | #3 (permalink) | |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Quote:
Solution pin and imei repair BlackBerry 8900 - 8u6 L04D3r Download here: 1309889800BUG - Download - 4shared - felipe orellana - Open the old RLT - Run the loader. - When finished charging the phone was disconnected - When turning the phone with LED and connect to the pc immediately connect you must give the RLT - Never workedon the first attempt , must bemany consecutive logrr RLT solution and recognize the phone . | |
02-20-2014, 15:28 | #6 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | |
The Following User Says Thank You to gcceleghg For This Useful Post: |
02-20-2014, 19:37 | #8 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Blackberry MEP 0, direct unlock, IMEI change, PIN change,BSN change ,debranding FAQ. Supported models: In our first balckberry release we made support for these phones: 9620, 9810, 9850, 9860, 9900, 9930, 9981. All other models currently not supported. WE are working for adding more phone, kindly wait for further announcements. Function description: Unlock button: Allows you to make direct unlocking without code reading and code imput, irrespective of the MEP type in phone. Also this button reset the MEP code entry attempts (0 left). Read code button: Allows you to read codes from your phone. Repair imei button: It`s purpose to change or restore original IMEI of your phone Remove operator logo button: Use it for full phone debranding - remove operator logo, reset vendor ID to to default one (-1) and return your cellphone to original factory settings. Price: Price 20 credits per phone for any number of operations (mep0 fix, unlock, IMEI repair, debranding). In order to use this feature your card must be registered and activated. Cable: To work with blackberry phones you should use Standart USB cable and modified SD card with power supply (+ 3.0 V) identical to set which you use for HTC phones. What is MicroSD cable set: You need 1) standart USB cable Click image for larger version. Name: BB_USB_cable.jpg Views: 2471 Size: 10.4 KB ID: 527 2) microSD card (8MB - 4GB, don't use SDHC) with two thin wires (pin4=+3V, pin6=GND) Click image for larger version. Name: modified_SD.jpg Views: 3407 Size: 31.2 KB ID: 528 3) External power supply (+3V or +3.7V, for example 2xAAA battery). Click image for larger version. Name: external_ power_supply_+3V.jpg Views: 1192 Size: 23.0 KB ID: 529 4) Any MicroSD USB card reader: Click image for larger version. Name: MicroSD_USB_cardreader.jpg Views: 884 Size: 6.3 KB ID: 530 How to work with this set with BLACKBERRY phones: Firstly you put card in external card reader WITHOUT EXTERNAL POWER and make phone image with LGtool and simple USB cable. after this you INSERT modified card to phone, CONNECT EXTERNAL POWER, connect USB cable to phone without battery and follow on-screen instruction. |
02-20-2014, 19:51 | #9 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | MFI 4.11 & RadioLabTool NEW SECURITY http://www.mediafire.com/download/54...T+2.13.224.rar The trick is the time between when the loader finishes loading and restarts until light, that is the time where they give the Pin Connect the RLT must try several times until you succeed, no more than 3 seconds have before you turn. Immediately after restart in boot loader mode after the PC recognizes it as a new device, then fixed in the device manager Keep him open, that is the exact time. Follow this sequence. 1 - Run the loader 2 - You open Radiolab 3 - Doing without battery 4 - Then insert the battery and wait for the red bulb out 5 - You will see that the computer is turned off and the usb is normal 6 - Inserting or removing the battery and repeat the process until you have left the team in white screen without leaving the error usb 7 - And there you hit connect, until you see connected |
