8900 keypad problem i have problem with the keypad of bb 8900 can anyone help me with the ic responsible for the keys control?i need help urgently |
open the phone then clean it,check flex kaypad also regards |
change flexibel for trackball... hope can solve ur problem :cool: |
ı have same prob. with bb. 8900 all of keys not working .i do same things but noting happened |
change the UI board thats all. |
i m change the UI board after coming same problem now what i do? |
u can change the keypad flex with complete one,it wil work 100% sure.good luck bro. |
u can also change the keypad ic first, b4 changing the keypad flex. if u can change the keypad ic, replace it with complete keypad flex it wil work 100% sure.good luck bro. |
I also had the same problem, just chande the middle frame with the keyfoil assy. problwm solved 100000% tested by me. |
ı change trackball board ang it's ok... thanks |
hj, pls is 8900 keypad flex repairable? if yes pls how? |
