Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > BlackBerry (RIM)
BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs.
Old 06-11-2012, 14:18   #1 (permalink)
bpcentergtk's Avatar
Member: 311436
Thanks Meter: 38
Arrow 9360 keypad
9360 Keypad,Sensor not working at all i tried restoring firmware but still same only volume up down key working if ny solution than plez provide in this thread
Old 06-12-2012, 06:38   #2 (permalink)
Member: 311436
Thanks Meter: 38
no solution???? in this forum no body had faced this type of problem!!!
Old 06-12-2012, 11:26   #3 (permalink)
Member: 311436
Thanks Meter: 38
wow 36 views but no comment
Old 06-17-2012, 15:21   #4 (permalink)
Member: 775741
Thanks Meter: 10
Two solutions that worked for me, disassembly phone and remove mini pcb, all plastics or rubber that may burn. Reheat aroung the shields that cover the chips. Do this at a low temp (recommend 250-270 degrees) maximum. Reheat both side of PCB while on vise at about 2 mins each, with 3 intervals. Let cool down for about 10 min. Second issue, these flex keyboards SUCK, remove and place on flat surface and roll with small round instrument. This helps to release sticky keypads. Or just replace the keypad with a new one and pray it WORKS.
Good Luck
Old 06-17-2012, 15:38   #5 (permalink)
R.Nasir.Ali's Avatar
Member: 1141761
Sonork: 100.1618159
Thanks Meter: 346
what is the problem
if your ? is not understood then you wont get answer
what r u facing key pad not working what do u mean by sensor not working
3210 ringer not working but keypad tones do??? bluelights Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 05-10-2010 06:47
509 keypad malfunction... read on :) trafix Various 9 03-02-2002 09:24
Problem with keypad on V3688!!!HELP!!! gsm4dcs Motorola Old Legacy (EMMI) 0 09-09-2001 00:27
How can i convert keypad tone to RTTL ? yaser Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-05-2001 18:29
Flashing keypad for 3210? laxxe Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 06-05-2001 23:01
Page generated in 0.13905 seconds with 9 queries
