Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > BlackBerry (RIM)
BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs.
Old 02-27-2015, 06:25   #1 (permalink)
Member: 946381
Thanks Meter: 150
9860 stuck in blackberry logo-flashed still same-help
after flash also bb9860 stuck in blackberry logo.
two times flashed-same-so i think it hardware.
which ic?
Old 02-27-2015, 07:45   #2 (permalink)
Member: 946381
Thanks Meter: 150
i saw in forum many friends have same problem-and good experinced guys answer as internal memory problem.try to heat it
i need schematic or show me this ic
Old 02-27-2015, 07:47   #3 (permalink)
Member: 1372118
Thanks Meter: 139
try disable internal memory with lgetool / volcano /miracle/ or BBFL
Old 02-27-2015, 07:50   #4 (permalink)
Member: 946381
Thanks Meter: 150
how the steps to disable in volcano?
Old 02-27-2015, 10:27   #5 (permalink)
Member: 619957
Thanks Meter: 50
1.use step1 nuke my phone batch file
2.use step2 wipe my phone
3 update with using auto flash loader by model
100% tested on many devices
if not solve then contact me i will solve ur problem via team viewer
Old 03-01-2015, 07:01   #6 (permalink)
Member: 946381
Thanks Meter: 150
STEP1 nuke details as below
Connecting to Bootrom: Connected
[ Erasing 0x0181FFFF ] [############## 100 ##############]
Connecting for Nuke:
Your device is currently being erased. Please wait for
the LED to extinguish before attempting to reload code.
This operation may take several minutes.
STEP 2: wipe details as below
[ Erasing 0x200FFFFF ] [############## 100 ##############]
Done.
STEP3: FLASH USING 9860-70-B1672 160mb file
did-still same stuck near 75%
changed battery also-no scope
help
Old 03-01-2015, 14:22   #7 (permalink)
Member: 619957
Thanks Meter: 50
if not solve then first full erase the phone with pb tool like any software after repaet full procedure again 101% tested on many 9860 and other bb devices
if not solve ur problem then give me ur tv me i will do all myself
Old 05-07-2015, 19:59   #8 (permalink)
Member: 1169702
Thanks Meter: 4
can you please share links for
Old 05-17-2015, 02:26   #9 (permalink)
Deni's's Avatar
Member: 1800628
Thanks Meter: 940
which ic?
just one solution ..make it disable BIMS.
Page generated in 0.13055 seconds with 8 queries
