Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > BlackBerry (RIM)
BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs.
Old 01-21-2013, 17:11   #1 (permalink)
zameer_yus's Avatar
Member: 774915
Thanks Meter: 1,640
9900 red light and restart 2pcs need help
i have 2 pcs 9900 one is very fresh phone and one was water damage
both have same problem red light and then restart i tried my best but no success i m posting full story and condition of phones with pictures
when i connect with computer without battery it show X mark on battery
when i connect with computer with low battery it show charging but when it store a bit charge again red light and restart
i tried to flash it with Fast flasher every thing was done but still same problem
nuke
wipe
after this i run fast intaller and its done but at the end installer windows just close and says nothing and still same
i tried to flash with no jvm , but phone is not reconnecting with jvm
also i tried to flash with desktop manager but no success
i changed the power ic , and the small ic for relight
this is my 5th phone without any success
now please help me what to do with these phones
The Following User Says Thank You to zameer_yus For This Useful Post:
Old 01-24-2013, 18:15   #2 (permalink)
zameer_yus's Avatar
Member: 774915
Thanks Meter: 1,640
no body have anything to say?
Old 01-24-2013, 19:43   #3 (permalink)
Member: 616931
u try lot...hope no 1 try more than u...soo i quite.
Old 01-26-2013, 10:29   #4 (permalink)
Moderator
tkowsar's Avatar
Member: 233205
Thanks Meter: 5,014
after charge few its show startup blackberry + progress bar on screen then restart or without startup screen its restart with batter sign only?
have u try to replace "U1305" ?
Old 01-26-2013, 10:36   #5 (permalink)
Member: 328688
Thanks Meter: 2,282
u need PBTOOL full erase then flash it hope it will help u i did fix many of them
Old 01-27-2013, 08:24   #6 (permalink)
zameer_yus's Avatar
Member: 774915
Thanks Meter: 1,640
it doesnt show startup screen or status bar
just red light for 2 3 seconds then turn off and then again red light
Old 01-27-2013, 08:58   #7 (permalink)
ansari123's Avatar
Member: 292789
Thanks Meter: 636
i have same problem in 5 phone i tried that as well but still problem is same
if phone get turn on after load full OS keep restarting !!!!!!!!!!!!!!!!
no success yet ??????/
Old 01-27-2013, 10:05   #8 (permalink)
dil_PAKISTANI's Avatar
Member: 515273
Sonork: 100.1573940
Thanks Meter: 339
1: Download & instle the blackberry flashfile (no need instle blackberry desktop manager)
2: Delete the vendor.xml file located in c:\program files\common files\research in motion\apploader
3: With battery Connect your BlackBerry device to your computer
4: Run Loader from c:\program files\common files\research in motion\apploader & click Next
5: Select all software you want installed.
6: Proceed to the end portion untill you see the "Finish" button
7: Very IMPORTANT. do not hit the finish button, instead select the ADVANCED button.
8: Make sure both boxes are checked.
9: Proceed until it ask you if you want to automatically back up and restore, Select DO NOT AUTOMATICALLY BACK UP MY HANDHELD do next
10: & wait for Your device's software has been updated successfully
Old 01-27-2013, 11:03   #9 (permalink)
Member: 1730888
Thanks Meter: 6
View Post
Old 01-27-2013, 11:04   #10 (permalink)
Member: 1730888
Thanks Meter: 6
done severeal times
but no sucess alwas showing recconect to jvm
Old 01-30-2013, 14:57   #11 (permalink)
zameer_yus's Avatar
Member: 774915
Thanks Meter: 1,640
i tried with app loader i also mentioned in my first post , no success with that always reconnecting to jvm
any other solution?
Old 01-30-2013, 14:57   #12 (permalink)
zameer_yus's Avatar
Member: 774915
Thanks Meter: 1,640
any other solution?
Old 01-30-2013, 19:47   #13 (permalink)
Member: 542837
Thanks Meter: 6
Many 9900 suffer from the same problem, I have worked a lot, but no success. Seems problem of recognition of the battery, but no problem of battery
Old 01-30-2013, 19:52   #14 (permalink)
Registered User
Member: 759011
Sonork: 164643 (server.sonork.com
Thanks Meter: 152
Chang power ic yourproblem 100% slove
alredy try and slove my problem
Old 01-31-2013, 13:18   #15 (permalink)
Member: 1876282
Sonork: 77059
Page generated in 0.31244 seconds with 8 queries
