Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2008 Location: TOKYO JAPAN Age: 32
Member: 747968 Status: Offline Sonork: 100.1621353 Thanks: 1,185
| 300-303 Bad load Run Application Loader to reload the operating system and applications onto the handheld. 395 Unclassified error code You receive the following error message on the handheld: Device Error 395 Cause Device Error 395 is an unclassified error code. This error can be caused by a third party application installed on the handheld. Resolution 1 Perform a hard reset on the handheld: Shut down, remove the battery wait a few second... replace battery then see when happens when it starts. Resolution 2 Erase and reload the data on the handheld. 1、In BlackBerry Desktop Manager, use the Backup and Restore tool to create a backup file of the data on your handheld. For instructions, see “Back up handheld information” in the Desktop Manager Online Help.Warning: The following steps will erase the data on the handheld. 2、In BlackBerry Desktop Manager, double-click the Application Loader icon. 3、Click Next. The Handheld Application Selection window appears. 4、Verify that the correct applications are selected, then click Next. 5、Click Advanced. 6、Select the option for Erase all application data and Erase all currently installed applications, then click Next. 7、Click Finish. The data on the handheld is erased, while the operating system and applications are reloaded onto the handheld. 8、Use the Backup and Restore tool to restore to the handheld the data saved in the backup file. For instructions, see “Restore handheld information” in the Desktop Manager Online Help. 400-564 Page faults Run Application Loader to reload the operating system and applications onto the handheld. 310-314 Hardware failure Perform a hard reset on the handheld: Shut down, remove the battery wait a few second... replace battery then see when happens when it starts. OR Run Application Loader to reload the operating system and applications onto the handheld. Note: If these tasks do not resolve the error, contact your service provider. 320-325 AMX failure Run Application Loader to reload the operating system and applications onto the handheld. 330-339 Application tasks failure Run Application Loader to reload the operating system and applications onto the handheld. 340-343 Memory failure You receive one the following error messages on your handheld: Device Error 340 Device Error 341 Device Error 342 Device Error 343 Cause Memory failure. Resolution Reduce the number of calendar appointments synchronized to your handheld. 1、In BlackBerry? Desktop Manager, double-click the Intellisync icon. Click Configure PIM. The Handheld Configuration window appears. 2、In the Handheld Applications list, select Calendar. 3、Click Configure > Advanced Settings. The Advanced Settings for Calendar window appears. 4、In the Date Range tab, perform one of the following tasks to reduce the number of calendar appointments synchronized to your handheld: If you click the Transfer only Future items option, only future calendar appointments will be synchronzied to your handheld. If you click the Transfer items within a range of Days option and enter date range in the fields provided, only the calendar appointments that scheduled within the date range will be synchronized to your handheld. 5、Click OK to save your changes and close the window. 7、In the Handheld Configuration window, ensure that the check box beside the Calendar application is selected, then click OK. 8、In the Intellisync window, ensure that the Synchronize PIM check box is selected, then click Synchronize Now. The number of calendar entries on your handheld is reduced. If you still receive the error Run Application Loader to reload the operating system and applications onto your handheld. 350-359 Software application failure You receive one of the following error messages on your handheld: Device Error 350 Device Error 352 Device Error 353 Device Error 354 Device Error 355 Device Error 356 Device Error 357 Device Error 358 Device Error 359 Cause Software application failure. Resolution Perform a hard reset on the handheld. OR Run Application Loader to reload the operating system and applications onto your handheld. In the Application Loader Wizard window, do not select any third party applications. In the Advanced options, select the Erase all currently installed applications check box 360-363 Flash memory failure Run Application Loader to reload the operating system and applications onto the handheld. 365-368 This one is often followed by "OHHH @&#%!!" Contact your service provider. 410 Radio failure Run Application Loader to reload the operating system and applications onto the handheld. Note: If this task does not resolve the error, contact your service provider. 507 No applications on handheld You receive one of the following errors on your BlackBerry device while using Application Loader to install device software: Device Error 505 Device Error 507 Both errors indicate that no applications are loaded on the BlackBerry device. Cause 1 During the Application Loader process, the existing applications on the BlackBerry device were erased, but Application Loader failed to load the new applications. Resolution Complete the following steps: 1、Verify that device software is installed on your computer. 2、If your BlackBerry device is connected to a laptop in a docking station, disconnect the laptop from the docking station and connect the device directly to the laptop. 3、If a third-party program (e.g. virus scanner) is using the same COM port as BlackBerry Desktop Manager, close the third-party application to free the COM port. 4、If you are using a USB adapter to connect your BlackBerry device to a serial port on your computer, temporarily connect your device to a computer with a USB port. 5、In Desktop Manager, double-click Application Loader. 6、Use Application Loader to install the device software. Cause 2 You erased all the data and applications on your BlackBerry device by typing an incorrect password ten times in Application Loader. Resolution Complete the following steps: 1、In Desktop Manager, double-click Application Loader. 2、Use Application Loader to install the device software Just press "thanks button" if these code useful |
| The Following 31 Users Say Thank You to VODAFONES For This Useful Post: |
| | #2 (permalink) |
| Junior Member ![]() ![]() Join Date: Sep 2005 Age: 35
Member: 178023 Status: Offline Thanks: 0
| 9700 and 8520 got problem, 1. 9700 once plug in usb cable to sync or charger it will hang,so i try to run the software and now problem is error 507,i cant complete the device inilization.it will failed and how many times i retry also same. 2.8520 before screen turn set ok,but once the screen light is on,pc will show usb device not found and error,so again i cant finish the device inilization and the set error 507 3. 9700 set very fast off,not enough time to do device inilization,so software cant finish and error 507 again please help thanks |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| All Blackberry Hardware and Software Solution | youssef01 | BlackBerry (RIM) | 36 | 12-01-2012 14:21 |
| ALL BlackBerry Meps Level & HTC qualcomm/Omap code reader ! Professional Services !! | MB code | Main Sales Section | 0 | 03-03-2010 01:33 |
| All blackberry unlock code free give me imei no + mep | vikas1 | BlackBerry (RIM) | 4 | 02-23-2010 19:51 |
| All BlackBerry Database Code Instant... | TaHiR | Main Sales Section | 0 | 08-23-2009 19:44 |
| BB5 & DCT4 Ask to RPL , Moto codes, Blackberry Worldwide Codes & Much More | viru | Main Sales Section | 0 | 09-05-2007 22:35 |
