Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > BlackBerry (RIM)
BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs.
Old 11-07-2011, 03:39   #1291 (permalink)
Member: 1684833
Mobile world.
Here you will find hope you like the phone. We will give you the best price and best service. Thank you!
Old 11-07-2011, 13:49   #1292 (permalink)
Member: 1323982
Sonork: 103184
Thanks Meter: 2
help... i have a vodafone BB 9500 from hungary,,,after i inserted the battery the clock onthe screen appears.. then after that it suddenly appears white screen.. what is the problem of my phone and how to solve it? thanks
Old 11-08-2011, 15:32   #1293 (permalink)
Member: 210830
Thanks Meter: 4
Originally Posted by x.ram View Post
bro where is your problems how can directly i give solution
i ve got a bb 9930 that went off and has refused to come back on and it has done this b4 and after scratching the battery pins it came on but now its not coming on at all after i ve done to it. pls help. thanxx alot in advance.
Old 11-09-2011, 02:17   #1294 (permalink)
Member: 1414945
Please I need code for:
Blackberry Torch 9800
IMEI: 355466046128488
MEP-06041-011
Thanks regards!
Old 11-09-2011, 21:31   #1295 (permalink)
Member: 242981
8300 keypad solution needed
i have two 8300 that the keypad on bought of them is not working, board #1 W,E,R is not working and board #2 W,Q,A,ALT, SPACE is not working can someone give me solution please
Old 11-10-2011, 11:51   #1296 (permalink)
Member: 118601
Thanks Meter: 200
9900 I WANT TO ADD FRENCH LANGUAGE
for me can't launch app loader only hang after install 9900 Flash file.even i remove and install destop manager no way.i try many files without success! how to make work App Loader after install firmware?
Old 11-10-2011, 18:48   #1297 (permalink)
Member: 1648116
Blackberry 9800
please somebody help, i have got a blackberry 9800 slide having the following problems; 1. when you dial a number the screen goes off while the upper segment keypad light remains on for about five minutes before it displays back and the dialed call will be cought off, but if you plug hansfree dialling, it works fine. 2. the navigation button does not OK, but scrolls fine. 3. when you plug charger to it the charger indicator light goes off. though it receives call fine ..........................................what can i do in this case ?
Old 11-10-2011, 19:32   #1298 (permalink)
Member: 1559773
Has this problem just recently started occurring?
Try restarting your phone + taking out the battery and putting it back on.
That usually did the trick for me.
Old 11-10-2011, 22:56   #1299 (permalink)
Member: 1592972
Thanks Meter: 5
my bbbold 9000 not charging i want to find the pinout for the charging port
Old 11-10-2011, 23:09   #1300 (permalink)
Member: 1592972
Thanks Meter: 5
Old 11-17-2011, 08:30   #1301 (permalink)
Member: 1317658
Sonork: prakash cellular service
Thanks Meter: 441
Smile
Originally Posted by Leutenant View Post
after installation, trying to run loader (vendor deleted), and get error xmlLite.dll missing..
how i can resolve it pls?
tnx in advance for any help!
Hi
First uninstall that file and again install that file your problem will solve
..:: X.Ram ::..
Old 11-17-2011, 08:34   #1302 (permalink)
Member: 1317658
Thanks Meter: 441
Smile
Originally Posted by kiryoku View Post
Hi there i got a blackberry storm 9530 and some keys on the touchpad are not functioning.. what could be the problem and its solution? thanks..
Hi
If your touchpad is not working it mean your touchpad is bad ... you have replace your device touchpad thats it no ...
..:: X.Ram ::..
Old 11-17-2011, 08:42   #1303 (permalink)
Member: 1317658
Thanks Meter: 441
Smile Blackberry 8520 Latest OS Download HERE
Originally Posted by cgoldar_ar View Post
hello bro, i have 8520 and reload software 507. what can i do????? thanks.-
Hi
This is software problem only all this kind of error related with software . you need charge battery and download this firmware after that
MY COMPUTER
C
PROGRAM FILES
COMMON FILES
RESEARCH IN MOTION
APPLOADER
Then click on loader and connect your device follow instruction
OFFICIAL: Curve 8520 Firmware 5.0.0.681
..:: X.Ram ::..
Old 11-17-2011, 11:57   #1304 (permalink)
Member: 297431
Thanks Meter: 7
blackberry with no meps left.
Solution Please
Old 11-17-2011, 18:00   #1305 (permalink)
Member: 887494
Thanks Meter: 3
bro i have 9700 bb it's has a problem when it's do wifing it reboot when in 53 percent always so it wont boot normally pls help me to solve my problem...thanks in advance
Anybody know solution Robi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 12-10-2014 12:35
Solution for GSM phones!?!?!?!? todosije Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 12-16-2010 05:52
Page generated in 0.29420 seconds with 10 queries
