BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
09-17-2012, 08:20 | #1 (permalink) |
Registered User Join Date: Jul 2012
Member: 1784151 Status: Offline Sonork: 0 Thanks Meter: 75 | BackBerry 9000 Loading Approx 75% and Restarting Code: Device Info: PIN: 255xxxxx Bootrom Version: 5.4.0.18 Hardware ID: 0x84000E07 RIM BlackBerry Device HW ID Override: None Supported Bands: 0x000F Metrics Version: 6.0 Build Date: May 28 2008 Build Time: 15:55:26 Build User: schen Security: Enabled Drivers: 0x00000004 LDR Blocks: 0x5C01E500 Bootrom Size: 0x00020000 External MCT/HWV: Enabled Boot Mode: N/A Boot OS Count: N/A HWV: Board Revision 0001 - 0x10 CPU Version 0002 - 0xE7 SW Compatibility 0003 - 0x02 POP Revision 0004 - 0x0B Power Mgt Hardware 0007 - 0x25 Mem Config Table (ver 1.14): Flash Chip: blocks 0-996, Chip 0, Sub 0 Bootrom: blocks 0-0 OS Dynamic: blocks 2-???? FS Dynamic: blocks ????-979 OS NV: blocks 980-996, total 17 CRC: 0x98588CE1 Flash: Number of chips: 1 Flash ID: NAND blocks 0-996 Device ID: 48 Vendor ID: 236 Version ID: 33 Total Size: 124.6 MB Memory Map: NAND Blocks: 997 * 128 Kb RAM Base: 0x80000000 IRAM Base: 0x5C000000 OS Range: 2 - 121 File System: Memory Map: 122 - 979 Sectors: 858 Branding: VendorID: 141 OS Version: 5.2.0.57 Hardware ID: 0x84000E07 RIM BlackBerry Device Supported Bands: 0x0000FFFF Metrics Version: 3.16 FS Code Version: 10.0.0.0 FAT Code Version: 2.32 Package Version: "5.2.0.57" Build Date: Mar 22 2010 Build Time: 18:14:34 Build User: absadmin SV Number: 40 OS Address: 0x80000000-0x80EFB61F App Start: 0x8070FE78 Companion Binary: 0.0.0.0 RAM usage: 0x86F3FFFC-0x876AFFFC IRAM End: 0xD0F902C8 DSP ROM2 Address: *not present* OS Extended Addr: 0x809A09C8 LDR Blocks: 0x80A88230 API Checksum: 0x00000000 JumpTable (<3): 0x800002D4 JumpTable (>2): 0x80002580 Radio Code: Janus radio code linked OS API Version: 130.3 STP Protocol Ver: 5.203.4 (release OS) HWV: Board Revision 0001 - [0x0C - 0xFF], 0x01 Board Revision 0001 - [0x09 - 0x09], 0x01 POP Revision 0004 - [0x00 - 0xFF], 0x01 CPU Version 0002 - [0xE7 - 0xE7], 0x01 CPU Version 0002 - [0xEA - 0xEA], 0x01 CPU Version 0002 - [0xEC - 0xFF], 0x01 SW Compatibility 0003 - [0x00 - 0x02], 0x01 Power Mgt Hardware 0007 - [0x23 - 0xFF], 0x01 WTE supported 003C - [0x01 - 0xFF], 0x00 Version Table: OS API Version: 130.3 STP protocol version: 5.203.4 BlockFS API Version: 10.0.0.0 USB driver version: 02.01 Bugdisp RTAS key: 1.0 STP RTAS key: 1.0 FAT FS Version: 2.32 Block map version: 2.15 WLAN radio version: 3.0.0.102 Kernel Version: 1.13.0.269 Hardware ID: 0x84000E07 RIM BlackBerry Device Metrics Version: 1.1 Build Date: Mar 22 2010 Build Time: 17:04:24 Build User: SCM App: Version: 5.0.0.592 (0x05000250) Metrics Version: 1.7 Build Date: Mar 22 2010 Build Time: 18:35:49 Build User: RIM Memory Map: 0x8070FE78-0x809A09C7 App c_main: 0x808D2D1C API Checksum: 0x00000000 JumpTable (<3): 0x00000000 JumpTable (>2): 0x00000000 AppFSVersion: 3.0.0.0 AppFSSize: 0x3200000 OS API Version: 130.3 RAM Map: 0x86E40000-0x86F40000 IRAM Map: Unused App Type: JVM Done. |
09-18-2012, 03:59 | #2 (permalink) |
No Life Poster Join Date: Apr 2010 Location: NYC/USA
Member: 1283129 Status: Offline Thanks Meter: 135 | Try using rapido again. If is doesn't work most likely some hardware problem. I never saw this on 9000 (I've sold thousands of them), but this problem is fairly common on 9700 and 9780. Usually not economical to repair. Also check for water damage. |
