Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > BlackBerry (RIM)
BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs.
Old 07-14-2010, 19:57   #1 (permalink)
miniman0's Avatar
Member: 120907
Thanks Meter: 6
BB 8520 no memory card recognised ?
Please can anyone come up with a solution to make the memory card be recognised, all settings are correct, several cards have been tried, but phone still does not find a memory card inserted.
Thanks.
The Following User Says Thank You to miniman0 For This Useful Post:
Old 07-15-2010, 07:52   #2 (permalink)
Member: 656076
Thanks Meter: 5
Thumbs up 8520 MMC problem
see back side on mmc strip connecter one loge black ic u see,hit it or change
The Following User Says Thank You to m zone For This Useful Post:
Old 07-15-2010, 07:54   #3 (permalink)
Member: 656076
Thanks Meter: 5
Thanks.
change or hit long black IC
Old 08-30-2010, 19:16   #4 (permalink)
Registered User
Member: 1125280
Thanks Meter: 273
there is three black long ic can you determean whech ic brother??
The Following User Says Thank You to JASKY007 For This Useful Post:
Old 01-26-2011, 14:24   #5 (permalink)
Moderator
chand_gee's Avatar
Member: 668050
Sonork: 100.1656307
Thanks Meter: 991
same problem any solid solution
The Following User Says Thank You to chand_gee For This Useful Post:
Old 01-26-2011, 18:22   #6 (permalink)
Member: 1326801
I just added u to my msn contact i need to talk to u about the media card issue on Blackberry 8520
Old 01-26-2011, 18:34   #7 (permalink)
nikhil_gsm's Avatar
Member: 47627
Sonork: 100.1596335
Thanks Meter: 124
Check for media card option Enabled/Disabled , before you go for hardware
regards
Old 01-26-2011, 18:35   #8 (permalink)
Moderator
chand_gee's Avatar
Member: 668050
Sonork: 100.1656307
Thanks Meter: 991
i have solved my problem resold mmc conector
specialy from front there is one pin which is
used as a switching.
Old 07-22-2011, 22:43   #9 (permalink)
celucables's Avatar
Member: 65115
Sonork: 100.71218
Thanks Meter: 72
Can u upload any image?
Old 09-21-2011, 10:17   #10 (permalink)
Member: 530674
did you find the sollution of mmc ??
Old 09-21-2011, 13:19   #11 (permalink)
miniman0's Avatar
Member: 120907
Thanks Meter: 6
No, not yet.
must now waffle as post has to be longer, not allowed short replies.
Old 09-21-2011, 23:09   #12 (permalink)
Member: 1645045
Thanks Meter: 23
Open the phone up and check your Memory card port on the main board, make sure none of the solder on the pins have came away and fully connected.
Also check inside the Memory card actual slot where it goes and make sure none of the pine have moved out of the grooves which they sit in.
Good luck...
Old 09-22-2011, 10:19   #13 (permalink)
jasir_kp's Avatar
Member: 705281
Thanks Meter: 55
just use Wipe Handheld‎ option - phone its ok
Old 09-22-2011, 12:36   #14 (permalink)
miniman0's Avatar
Member: 120907
Thanks Meter: 6
Wipe removes data, this isnt a data problem, so how does your solution work ?
Old 08-26-2015, 16:13   #15 (permalink)
Member: 2268438
Sonork: 100.1667123:Flasher
help my bb 8520 problem slot MMC Card
SIM card readers Ryu Hardware Equipments for GSM 7 10-30-2007 09:11
NOKIA TECHNICAL SERVICE BOOK AND NOKIA SERVICING SIM CARD FOR SALE TRADE FOR 7110 andrew bennett Main Sales Section 0 07-09-1999 10:41
Page generated in 0.24336 seconds with 9 queries
