BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
12-25-2011, 17:42 | #2 (permalink) |
Insane Poster Join Date: Aug 2011 Location: el carmen M.
Member: 1630737 Status: Offline Thanks Meter: 27 | q recomindo friend you will spend a quick installer http://www.mediafire.com/?wyu4d6obod76b0w or You can also reset the bb with this loader to flash and then the application loader formateo para reparar blackberry.rar - 4shared.com - online file sharing and storage - download |
12-25-2011, 17:57 | #3 (permalink) | |
Freak Poster Join Date: Jan 2008 Location: Bangladesh
Member: 671937 Status: Offline Sonork: 100.1613181 Thanks Meter: 94 | Quote:
THANKS & BR | |
12-25-2011, 18:48 | #4 (permalink) |
Member: 1630737 Status: Offline Thanks Meter: 27 | 1.-This file does is that formats directly from your blackberry memory thus allowing delete any files that cause problems during the upgrade. 2.-To format your blackberry just run the FORMAT file BB.no use if your blackberry works perfectly, this is only for when you turn on, which only show the clock on the screen or flashing red lights. 3.-to install the new OS on your blackberry, first install the software that you can download from the official page and make sure it is for your operator if it were not then run the delete vendor file after installation, the is a file type you need the desktop manager ejecutable.tambien, lower than the same page (it's already version 5.0 in Spanish) 4.-When you open the desktop manager software already installed on your blackberry, then you go where it says Application Loader, then where it says update software, then leave a window that says connect device, at this time you connect your blackberry and just when it says USB PIN UNKNOWN quickly give him the box OK, this is to prevent automatic disconnection of your cellphone and help so that the program reads it perfectly. 5.-Once the desktop read your phone will tell you the version of software you have installed on your computer, you go to options and tick the boxes you want to install on the blackberry, for example: BrickBreaker, yahoo messenger, windows live, Spanish language, among others, then you give complete and begin to update your blackberry. 6.-after update window says waiting for device connection, do not touch and expected to turn one (blackberry). 7.-If you get out a blank screen with lots of fine print in your blackberry press START course and the white screen disappears and started the last update process. 8.-After the update just have to wait about 25 minutes to turn on normally. 9.-To release you need a program called MFI Multiloader, just google for free (it has only a 6mb executable and 7 parts of 100 mb. 10.-This is proven by me and works perfectly, I'm not responsible for the misuse of these files, it is informative and educativo.Cada level who takes responsibility for its use. The vendor file deleter is for xp English and Spanish, Maybe Then add support for more operating systems. The delete command was created x me, I got the loader.exe x network there. Salu2 ... |
12-25-2011, 21:15 | #5 (permalink) | |
THANKS & BR | |
02-22-2012, 15:45 | #8 (permalink) | |
Junior Member Join Date: Aug 2006
Member: 336243 Status: Offline Thanks Meter: 2 | Quote:
02-22-2012, 20:25 | #9 (permalink) | |
Insane Poster Join Date: Feb 2008 Location: dhaka/UAE
Member: 696177 Status: Offline Thanks Meter: 24 | Quote:
good job nice working bro... | |
The Following User Says Thank You to bdlrazu008 For This Useful Post: |
BLUE light | Delfo | Nokia Hardware & Hardware Repair | 8 | 09-20-2002 04:28 |
5110/6110 after unlocking see only network to which it was locked and ... | 2M | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 07-25-2000 00:51 |
Only MAX232 ??? | AMIGO | Nokia Hardware & Hardware Repair | 7 | 04-12-2000 09:41 |
£20 only NOKIA 51xx/61xx sp locks 1,2,3,4 removed | spterminator | Main Sales Section | 0 | 08-08-1999 05:08 |
i can unlock nokia 51xx/61xx sp locks 1,2,3,4 £40 each £30 bulk for u.k only | spterminator | Main Sales Section | 0 | 08-01-1999 05:46 |
