Go Back   GSM-Forum > GSM Mobile Brands -Software Area- > BlackBerry (RIM)
BlackBerry (RIM) All Blackberry Models will be covered here.
Old 02-22-2012, 07:58   #1 (permalink)
mccm's Avatar
Member: 173565
bb 9700 blink twice
phone are blinking twice red led when usb connected w/o battery or with battery inserted.
App loader lost connection when reading arm.
Any suggestion ?
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiShare on FacebookTwitterStumble this Post!
Old 02-22-2012, 18:34   #2 (permalink)
Member: 125632
its blinking you a binery error code,,,
use search
on off on off on off that is 101010
you get the idea....
Old 02-22-2012, 19:14   #3 (permalink)
Member: 696177
its hardwear problam all borad resulder next time updat me be work
Old 02-23-2012, 10:27   #4 (permalink)
Member: 1243993
Sonork: +6287846666699
this the eror code.... for bb...
• 1 (desimal = 1) no problem, kode normal when restart
• 11 (desimal = 3) Tno system in blackberry use MFI or reload sistem operasi (use nojvm)
• 101 (desimal = 5) Bad OS CRC
• 111 (desimal = 7) Missing OS CRC
• 1011 (desimal = 11) Missing OS Trailer
• 1101 (desimal = 13)OS Not Signed, try to update os again
• 1111 (desimal = 15) OS Signature Invalid, reloadi OS dan dont put the batt for 30 minute, then on off again. if stiil same, problem with ic flash.
• 10101 (desimal = 21) Unknown Flash Manufacturer, ic flash
• 10111 (desimal = 23) Flash Initialization Problem, ic flash
• 11011 (desimal = 27) Flash Erase Failure ,change ic flash
• 11101 (desimal = 29) Flash Operation Out Of Range
• 11111 (desimal = 31) Bad BootROM CRC, ic flash was damage
• 101101 (desimal = 45) No BootROM CRC
• 101111 (desimal = 47) Flash Write Failure, bad ic flash
• 110101 (desimal = 53) Invalid Memory Configuration Table
• 110111 (desimal = 55) Password Not Initiated
• 111011 (desimal = 59) RAM Initialization Problem, coba lakukan penggantian flash
• 111101 (desimal = 61) Cache No Pages Free
• 111111 (desimal = 63) Cache Invalid Page Type
• 1010101 (desimal = 85) Random Number Failure
• 1010111 (desimal = 87) OSStore Failure
• 1011011 (desimal = 91) Security Init Failure
• 1011101 (desimal = 93) NAND failure
• 1011111 (desimal = 95) General Assert Failure
• 1101011 (desimal = 107) GPIO failure
• 1101101 (desimal = 109) Runtime library failure
• 1101111 (desimal = 111) Exception: undefined isntruction
• 1110101 (desimal = 117) Exception: SWI
• 1110111 (desimal = 119) Exception: Prefetch Abort
• 1111011 (desimal = 123) Exception: Data Abort
• 1111101 (desimal = 125) Exception: Reserved
• 1111111 (desimal = 127) Exception: IRQ
• 10101011 (desimal = 171) Exception: FIQ
Blackberry Device Failure Error Codes
25
Blackberry Error Codes
Guide to Toubleshoot and Repair Blackberry Device Failure Error Codes
300-303 Bad load
Run Application Loader to reload the operating system and applications onto the handheld.
395 Unclassified error code
400-564 Page faults
310-314 Hardware failure
Perform a hard reset on the handheld: Shut down, remove the battery wait a few second… replace battery then see when happens when it starts.
OR
Note: If these tasks do not resolve the error, contact your service provider.
320-325 AMX failure
330-339 Application tasks failure
340-343 Memory failure
350-359 Software application failure
360-363 Flash memory failure
365-368 This one is often followed by “OHHH @&#%!!”
Contact your service provider.
410 Radio failure
Note: If this task does not resolve the error, contact your service provider.
507 No applications on handheld
JVM Error Code
101 Internal JVM error.
102 Invalid code in file system. The .cod files in the handheld have been checked for modification and it has been determined that there is a problem with one or more .cod files.
103 The starting address for the boot .cod file cannot be found. This might mean that a boot .cod file has not been installed on the handheld, or that its format is invalid or corrupt.
104 An uncaught Java exception was thrown in the Java code and diagnosed by the JVM. Execution can be continued or the handheld can be attached to a debugger on a desktop through a serial or USB cable. The event log should contain the traceback of the thrown exception.
105 An OS file system API returned an error status for a certain operation. This can indicate a corrupt file system or an error in the JVM.
106 An error has been detected in the graphics system of the handheld.
107 Internal JVM error.
108 Internal JVM error.
109 Internal OS error.
110 Non-idle event downtime error. A problem has been detected in the accumulation of JVM down time that represents how long the JVM has been idle. This indicates an error in either the OS code or the JVM code.
200 Application manager threw an uncaught exception. The application manager event thread threw an uncaught exception and so cannot continue running.
201 Initialization of the cryptographic system failed and the handheld cannot continue to operate.
202 An attack on the key store has been detected, and the handheld cannot continue to operate.
203 The application manager console process, usually the Home screen ribbon, has failed, like due to an uncaught exception.
501 Internal error.
502 All processes exited. The last Java process has terminated, and there is nothing left to execute.
503 Internal error.
504 Internal error.
505 Internal error.
506 An uncaught Java exception was thrown in the initial VM Java thread thus killing the only live thread in the system. The event log contains the traceback for the exception.
507 A dependency on a .cod file could not be satisfied due to a missing .cod file. Load the missing .cod file onto the handheld.
508 Invalid object. A problem has been detected with a debugger command to the VM.
516 Error occurred during garbage collection, which might indicate a corrupted file system.
510 All threads are waiting on objects, which results in a deadlock. The system cannot recover from this state since no thread can release a lock.
511 A problem has occurred during debugging.
515 The reachable objects form a group that cannot be represented properly by the VM because there are too many objects or the total size of the objects is too large.
516 When committing a persistent object, the VM found that the persistent store id counter has reached its limit. The object was not committed.
517 An inconsistency has been detected in the VM persistent object store.
518 Internal error.
519 Internal error.
520 Internal error.
521 Indicates that Object.wait() has been executed by a thread that holds a lock on another object; occurs only in simulator if the JvmDebugWaits application switch.
522 A thread has acquired two locks on objects in an order that doesn’t match the order that previous locks for the two types were acquired, which indicates a future potential deadlock situation; reported only in the simulator when the JvmDebugLocks application switch is set.
523 A critical Java process has died and the device cannot continue to operate normally.
524 An object has been marked as recovered by the Low Memory Manager but it was not freed during a garbage collection. This is only checked in the simulator under the control of the JvmDebugLMM application switch.
525 Bad persistent object. An auto-commit operation during a garbage collection has detected a non-persistent object reachable from the persistent store root. The type of the object has been output into the event log.
526 The class definition for java.lang.Object cannot be found.
527 The class definition for java.lang.String cannot be found.
528 The file system is corrupted. Data on the handheld is unrecoverable.
529 The file system is corrupted. An attempt is going to be made to recover data, but some data might be lost.
530 Internal JVM error.
531 Flash memory has been exhausted.
532 A JVM assertion has been violated. This error can occur only in the simulator, not on an actual handheld.
mito.best@yahoo.com
The Following User Says Thank You to mitobest For This Useful Post:
Old 02-23-2012, 14:18   #5 (permalink)
Darkensser's Avatar
Member: 1709479
Sonork: Darkensser
Any suggestion ?
my friend... I just had this same problem, I recommend you install the os using the Desktop Manager.
The Following User Says Thank You to Darkensser For This Useful Post:
Old 02-23-2012, 21:26   #6 (permalink)
Crazy Poster
Member: 1713576
Sonork: 160290
i cant connect update my device with the desktoop manager....it says the application loader encountered problem
Old 02-23-2012, 21:27   #7 (permalink)
Crazy Poster
Member: 1713576
Sonork: 160290
can you share what to do i have the error 507 on the displayt
Old 02-23-2012, 22:32   #8 (permalink)
Darkensser's Avatar
Member: 1709479
Sonork: Darkensser
my friend.. the error 507 Reload Software... download
9700-600-b2115_instaladorrapido_os_version_6
start this application and connect your device!
LUCK!
Old 02-26-2012, 16:59   #9 (permalink)
Member: 1243993
just upgrde new version is still same try to hardware...
Old 02-26-2012, 17:02   #10 (permalink)
Member: 1243993
my sugestion :1 use rapido file
:2 full erase with mfi
:3 rehot ic flash.....
for my problem ......done with full erase with mfi and update to first os....goodluck
Where can i download program for blinking sms Ari Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 15 01-29-2009 16:47
please help "in c25 v10 light automatically blinks and switches off " sidharthaharish x1x to x45/x50 2 12-29-2001 21:40
AF.7F.BB + lp06 dihalt Old Legacy Motorola (EMMI) 6 12-28-2001 14:24
Help need 3330 Ver.305 double blink CS repairer ced1298 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 08-29-2001 18:13
A 36 Blink and off pez8210 x1x to x45/x50 0 08-05-2001 22:23
Powered by Searchlight © 2012 Axivo Inc.
- GSM Hosting Ltd. - 1999-2011
Page generated in 0.37563 seconds with 10 queries
