Unlock Server
Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > BlackBerry (RIM)
BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs.
Old 03-14-2009, 15:33   #1 (permalink)
Member: 961682
Blackberry 8120 JVM Error 547 Help needed pls
Ive got this blackberrry 8120 from a freind, and i ve tried every single firmware ive got an always in the middle of flashing process it says JVM Error 547 Fail Flash Write, first time ive got this error with a phone sooo many times... ive tried everything and its the same.... pleaseee i really need some help here guys...
Old 06-25-2009, 10:51   #2 (permalink)
Member: 109755
SOLVED PROBLEM
I got one bb 8310 with same problem JVM error 547
after full flash same error jvm error 547
then I solve problem with flashing only Uk lang-after that phone boot in normal mode,go to menu all ok
and if U need tnen U can flash all langs,maps...
br Kostadin
Old 01-31-2010, 23:30   #3 (permalink)
Member: 291218
8120 jvm 547
not solved as yet on mine 8120
Old 02-01-2010, 03:53   #4 (permalink)
voltran2008's Avatar
Member: 861795
Originally Posted by kostadin-yu View Post
SOLVED PROBLEM
br Kostadin
interesting I have a BB just with same problem will test it... thanks for the tip...
BlackBerry 8700g - JVM Error 102 - Solution here! Cryspim BlackBerry (RIM) 10 12-21-2010 16:56
bb 8100m jvm error 547 help delux_gsm HTC & Smartphones ( WM Without Touch) 3 12-24-2009 09:49
jvm error 547 flash write failed solution??? shoktong BlackBerry (RIM) 1 07-09-2009 06:04
8120 jvm error 513? mint centre BlackBerry (RIM) 4 12-17-2008 21:57
Page generated in 0.40018 seconds with 11 queries
