Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > BlackBerry (RIM)
BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs.
Old 12-13-2008, 12:17   #1 (permalink)
patric's Avatar
Member: 8228
Thanks Meter: 123
Red face blackberry 8320 flash file needed
i need flash file for blackberry 8320 to use it for unlock
thx in advance
Old 12-13-2008, 14:17   #2 (permalink)
Member: 367846
Thanks Meter: 28
Look here: http://www.uniksupport.com/index.php...rry/FIRMWARES/
Old 04-10-2010, 11:59   #3 (permalink)
Member: 1241427
Thanks Meter: 3
file does not exist boss checkyour link
Old 04-10-2010, 13:29   #4 (permalink)
Member: 965657
Thanks Meter: 51
here:
BlackBerry Handheld Software v4.5.0.306 (Multilanguage)
Package Version: 4.5.0.306
Consisting of:
* Applications: 4.5.0.182
* Software Platform: 2.7.0.106
* File name: 8320M_PBr4.5.0_rel306_PL2.7.0.106_A4.5.0.182_AT_am p_T.exe
* File size: 92.26MB
Note: The Software Platform and Applications version numbers can be found under Options-About screen on the handheld.
* Download Software: https://www.blackberry.com/Downloads...E4F82F9F00E7D4
This download will work on ANY carrier's 8320 model BB. (Not 8300, 8310, 8330, or 8350i)
1. Download the above OS file to the PC then install it to the PC by running (double clicking) the file you downloaded. (Vista users be sure to right click on the .exe file and select "Run As Adminstrator.")
2. Go to c:\program files\common files\research in motion\apploader and delete the file named "vendor.xml." Vista/Win7 users: In the apploader folder, simply click on "Compatibility files" to see the actual Vendor.xml file. Once you've got that - simply delete the vendor.xml file there (even if you've deleted or think you've deleted it in the folder previously) and voila, it will allow you to update to the newly installed OS!
3. Plug in BB and double click on "Loader.exe." It's located in the same place as the above vendor.xml file.
The process takes about 45 minutes to an hour depending on how much data you have to backup and restore during the process. Once it's done loading the new OS it will reboot (it may do this twice during the entire process.) You will see a white screen with an hourglass for up to 20 minutes at a time while the DM says "waiting for initialization."
If, for some reason, you end up with a white screen with small icons and the number 507, simply connect to the PC again and run Loader.exe again and it should load the OS to the device.
Previous OS version here: http://www.blackberryforums.com/gene...ilanguage.html
The Following User Says Thank You to d1ulove For This Useful Post:
need blackberry 7105t flash file *Overseasunlock* FuriousGold 3 11-24-2010 16:26
Need Blackberry 8820 Flash File rocky telecom BlackBerry (RIM) 4 02-03-2010 17:02
Searching for blackberry 8320 flash memory ic p802aaa Wanted Products 2 07-06-2009 03:58
Blackberry 7100t flash file need aukonline FuriousGold 2 01-31-2009 12:15
7105 blackberry flash file needed MAHMOOD FuriousGold 1 07-04-2008 16:47
Page generated in 0.31055 seconds with 8 queries
