blackberry 8520 loading 75% only blackberry 8520 loading 75% only.... any body have this solution...?? pls post it thanks advance...!!! http://img43.imageshack.us/i/img00014201102172231.jpg/ br http://img43.imageshack.us/i/img00014201102172231.jpg/ |
just flash the phone using the apploader and it will be fine... hope it helps... :D |
How long have you let it sit at that screen? Sometimes it can take a while if it just after flash. Download the latest software here for the 8520. Install it and remove the vendor file. Depending on what your operating system is it should be in C:\Program Files\Common Files\Research In Motion\AppLoader or if you have x64 operating system C:\Program Files (x86)\Common Files\Research In Motion\AppLoader In that folder create a shortuct to loader.exe, modify the shortcut and put -nojvm on the end like this "C:\Program Files \Common Files\Research In Motion\AppLoader\Loader.exe" -nojvm Download JL_Cmder from here Run JL_Cmder and do a wipe of your blackberry Once your blackberry is wiped use the Loader.exe shortcut and try and start your blackberry again from there. Hope this helps, if it does click thanks |
I have done all the suggestions but to no avail... This screen lasted until baterai discharged... Still waiting for some hint on how to fix this problem...:)) thanks advance...!!! Regard. |
it is a memory problem. you have to reflow memory |
Blackberry 8520 updating File change karka theko phi........................ |
external memory whether you mean sir.....:)) |
just downgrade OS version and post result here B,R Sparrow |
can be solved on hardware for sure |
downgrade cant be complete |
mfi cant erase firmware use new loader and flash again Quote:
hardware...?!?!? Could you show the picture sir....:)) br IyhAN bOy |
