Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > BlackBerry (RIM)
BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs.
Old 02-18-2011, 19:31   #1 (permalink)
iyhan boy's Avatar
Member: 1290467
Thanks Meter: 180
blackberry 8520 loading 75% only
blackberry 8520 loading 75% only....
any body have this solution...??
pls post it thanks advance...!!!
br
Old 02-18-2011, 19:47   #2 (permalink)
iyhan boy's Avatar
Member: 1290467
Thanks Meter: 180
see this
still waiting for some hint on how to fix this problem...)
br.
Old 02-18-2011, 19:53   #3 (permalink)
gsm_freak's Avatar
Member: 205990
Thanks Meter: 73
just flash the phone using the apploader and it will be fine... hope it helps...
The Following 2 Users Say Thank You to gsm_freak For This Useful Post:
Old 02-18-2011, 19:55   #4 (permalink)
Member: 1514219
Thanks Meter: 3
How long have you let it sit at that screen? Sometimes it can take a while if it just after flash.
Download the latest software here for the 8520. Install it and remove the vendor file.
Depending on what your operating system is it should be in
C:\Program Files\Common Files\Research In Motion\AppLoader
or if you have x64 operating system
C:\Program Files (x86)\Common Files\Research In Motion\AppLoader
In that folder create a shortuct to loader.exe, modify the shortcut and put -nojvm on the end like this
"C:\Program Files \Common Files\Research In Motion\AppLoader\Loader.exe" -nojvm
Download JL_Cmder from here
Run JL_Cmder and do a wipe of your blackberry
Once your blackberry is wiped use the Loader.exe shortcut and try and start your blackberry again from there.
Hope this helps, if it does click thanks
The Following 3 Users Say Thank You to nickds For This Useful Post:
Old 02-19-2011, 17:02   #5 (permalink)
iyhan boy's Avatar
Member: 1290467
Thanks Meter: 180
I have done all the suggestions but to no avail...
This screen lasted until baterai discharged...
Still waiting for some hint on how to fix this problem...)
Regard.
Old 02-20-2011, 05:36   #6 (permalink)
Cheater -Don't Deal with him-
Member: 110715
Sonork: -
Thanks Meter: 234
it is a memory problem. you have to reflow memory
Old 02-20-2011, 08:55   #7 (permalink)
somi.k.j's Avatar
Member: 1308377
Sonork: somi.k.j
Thanks Meter: 6
Blackberry 8520 updating
File change karka theko phi........................
Old 02-20-2011, 16:29   #8 (permalink)
iyhan boy's Avatar
Member: 1290467
Thanks Meter: 180
external memory whether you mean sir.....)
The Following User Says Thank You to iyhan boy For This Useful Post:
Old 02-20-2011, 16:59   #9 (permalink)
Member: 1519660
Thanks Meter: 2
just downgrade OS version and post result here
B,R
Sparrow
The Following User Says Thank You to JACK.SPARROW For This Useful Post:
Old 02-20-2011, 18:05   #10 (permalink)
Member: 1286359
Thanks Meter: 25
can be solved on hardware for sure
The Following User Says Thank You to ajmal143trait For This Useful Post:
Old 02-20-2011, 18:07   #11 (permalink)
Member: 1286359
Thanks Meter: 25
downgrade cant be complete
Old 02-20-2011, 18:57   #12 (permalink)
Member: 110715
Sonork: -
Thanks Meter: 234
I mean memory circuits
The Following User Says Thank You to luigivsf For This Useful Post:
Old 02-21-2011, 02:35   #13 (permalink)
Gabiunlock's Avatar
Member: 710759
Sonork: No
Thanks Meter: 320
mfi cant erase firmware use new loader and flash again
Originally Posted by robier gsm View Post
bro.
erase the phone by mfi
then reload softwaer
The Following User Says Thank You to Gabiunlock For This Useful Post:
Old 02-21-2011, 02:50   #14 (permalink)
Member: 180903
Sonork: 100.1637253
Thanks Meter: 66
can u show where is this memory on the board plz
Old 02-21-2011, 02:54   #15 (permalink)
iyhan boy's Avatar
Member: 1290467
Thanks Meter: 180
hardware...?!?!?
Could you show the picture sir....)
br
IyhAN bOy
5110/6110 after unlocking see only network to which it was locked and ... 2M Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 07-25-2000 01:51
Only MAX232 ??? AMIGO Nokia Hardware & Hardware Repair 7 04-12-2000 10:41
NEW ERICSSON A1018 60 SIEMANS C25 60 + LOADS MORE MILLENNIUM-INTERNATIONAL Main Sales Section 0 08-31-1999 19:54
20 only NOKIA 51xx/61xx sp locks 1,2,3,4 removed spterminator Main Sales Section 0 08-08-1999 06:08
i can unlock nokia 51xx/61xx sp locks 1,2,3,4 40 each 30 bulk for u.k only spterminator Main Sales Section 0 08-01-1999 06:46
Page generated in 0.48128 seconds with 8 queries
