BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
06-15-2009, 09:45 | #1 (permalink) |
Freak Poster Join Date: Jul 2007 Location: dubai
Member: 539557 Status: Offline Thanks Meter: 193 | blackberry 9000 keypad problem help for keypad ic call ang end call not working center ok for mouse also not work?? any body help me pls??iits not water damage maybe this line is cut |
The Following 2 Users Say Thank You to jhoesteve For This Useful Post: |
11-03-2009, 17:21 | #6 (permalink) |
Registered User Join Date: May 2007 Location: Canada
Member: 514340 Status: Offline Thanks Meter: 68 | remove the white pad hi, remove the white sticker on top of the keyboard. remove the camera and dip in alcohol for 1 hr. take it out and dry it completely and give it a try. I had 2 units with same issue and resolved using steps above.. good luck |
The Following User Says Thank You to lankan For This Useful Post: |
01-02-2010, 18:10 | #10 (permalink) |
Junior Member Join Date: Aug 2004 Age: 44
Member: 78472 Status: Offline Thanks Meter: 3 | hi boys i have same problemwith this model, its line on/off call, joy ok, and A, i think its have short near rollball cover... try this and reports |
The Following User Says Thank You to sooltys For This Useful Post: |
05-06-2010, 21:39 | #12 (permalink) |
Freak Poster Join Date: Mar 2005 Location: UK/Estonia
Member: 126943 Status: Offline Thanks Meter: 5 | Hi, if that will help you , use optic-fibre pen to clean keyboard and the area around water damage. Works for me in 99% If not sorry, diagram and tester =) |
blackberry 9000 keypad problem | 55533faisal | BlackBerry (RIM) | 2 | 03-01-2010 22:45 |
Blackberry 9000 keypad. | Adil Mobiles | BlackBerry (RIM) | 0 | 02-16-2010 19:47 |
BLACKBERRY 9000 unlocking problem | luqmaan751 | FuriousGold | 3 | 11-07-2009 08:26 |
blackberry 9000 mic problem | jayanandana | BlackBerry (RIM) | 0 | 10-19-2009 18:39 |
Blackberry 9000 unlock problem "Reload Software: 513" !? | mayer | FuriousGold | 4 | 07-25-2009 14:53 |
