Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > BlackBerry (RIM)
BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs.
Old 03-17-2009, 13:32   #1 (permalink)
Member: 458909
Blackberry 9000 lcd no lights
I have a Blackberry 9000. Came in with slight liquid damage on lcd connector. Cleaned, but now the lcd display without backlight. Is this a faulty lcd? I cant find a lcd for this model. Please help.
Old 04-23-2009, 15:02   #2 (permalink)
Member: 458909
Still need help re this problem. Please help.
Old 04-24-2009, 16:10   #3 (permalink)
Member: 72951
If you have another good working 9000 LCD, try it and see if the back light comes on. If it does, then you need to change LCD. If not, then re-flow display driver.
The Following User Says Thank You to cracker_jack For This Useful Post:
Old 04-24-2009, 23:00   #4 (permalink)
Member: 790054
www.cnn.cn they will sell you a brand new oem 9000 lcd
The Following User Says Thank You to jme2712 For This Useful Post:
Old 04-25-2009, 13:51   #5 (permalink)
Member: 152547
Sonork: 100.1586021
it is a hardware problem i think. i have before on 8310 curve
Old 04-29-2009, 07:56   #6 (permalink)
Member: 458909
Thanks, will order new lcd and post results. I hope it is lcd, because i found live ants on LCD connector. Did clean it up nicely, but lcd lights still off.
Old 06-25-2009, 06:42   #7 (permalink)
Member: 458909
Problem solved- broken track on main pcb close to connector.
Old 07-06-2009, 21:29   #8 (permalink)
Member: 1069109
Hi, I have the exact same problem where did you repaired? what was it?
thanx
Old 09-04-2009, 16:52   #9 (permalink)
Member: 235703
i have same problem on bb 8800 , phone works perfectly but not display and back light, and LCD is ok,can anyone help out with a solution?
Old 09-07-2009, 09:17   #10 (permalink)
Member: 458909
Carefully examine lcd connector on pcb under microscope. You will see broken track between connector and diode. Just bridge and it will work again. If you can upload a pictur of the connector i can show you where is led positive track.
Old 01-18-2010, 08:07   #11 (permalink)
Member: 742806
Sonork: 17532048
Dear gys blackberry 8310 no lighi lcd please help me
d900i no lcd, no light! chimeto Samsung Hardware Repair Area 12 03-23-2012 15:14
[help] 5310 no display after repair LCD no light thonylvs Nokia Hardware & Hardware-Repair Area 0 01-14-2010 02:33
s500 colour lcd no light samshl Samsung Hardware Repair Area 1 08-09-2005 17:49
d500 lcd no light tony84 Samsung Hardware Repair Area 6 07-20-2005 11:49
6230 keypad & lcd no light Alex8392003 Nokia Digital Core Technology 4 ( DCT-4 ) 6 06-12-2005 12:59
Page generated in 0.31568 seconds with 11 queries
