blackberry 9000 red blink i got a blackberry 9000 red blinking i think that someone killed it when trying to unlock can't connect it to computer because it can't detect it any solution to repair it ? |
try to take the batterie out and than connect it to the pc. After that follow the steps from the sticky threads "no software update needed" That should help. kr, Sena |
problem not solved !! |
Doing the recovery works. Just be patient. Try the loader /nojvm from dos prompt. Its an art of patience and timing. |
Already posted and working perfectly: Remove battery from blackberry & connect without battery to pc then Windows XP: Start / Run... type > cmd You will see a black window. Quote: CD \ CD PROGRA~1 CD COMMON~1 CD RESEAR~1 CD APPLOA~1 LOADER /NOJVM copy and past this QUOTE to command prompt exe After When you hit enter at the last command a forced will start application loder then update os your blackberry , when application loder come this massage like on pic > wait for device initialize , then insert battery on blackberry , dont touch/disconnect cable. luck |
I have faced this problem for over 10 phones different types and with the same symtomps (red blink), and using 4 different , and try all the solutions that people in this forum tell what to do, but still no luck, so it's better to try Hardware Solutions.... But because Blackberry Schematics is hard to find, so what we can to do is working BLIND...just reheat / rework IC....that's what we all can to do right now... Untill our Moderator/Expert is this forum share the solutions for all member... Best Regards, YM : [email protected] |
some body already to tell all about red blinkking if 11,2,11 it means 11 times blink and 2 sec no blink, and 11 times blink it is boot loader is missing or demage..... please corrected if i am wrong, and it realy means is hardware problem...... |
same problem here since 20 days but no solution i just unlock blackberry 9000 with MFI and try to flash with Desktop Manager i think i select wrong option after flash phone get error and power off now phone red light blinking and not attach to the computer. Can I flash phone with comport? |
1 Attachment(s) no Connection because phone not contecting to the computer how do i conect this is brand new phone. |
dont put battery first connect usb to computer without battery sure phone will be detected bro rock23 |
is not i tried 100 of time with and without bettary |
bro try to use mother board usb sometime phones cannot be detected by front usb of cpu but detected well on mother board usb and donot use any extension direct motherboard usb regards |
me to was facing this problem on bb9000 but i tried to again unlock on mfi and it did then i flashed it if not working with u try try it on another computer |
