BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
06-15-2010, 20:30 | #46 (permalink) |
Junior Member Join Date: Nov 2006
Member: 400635 Status: Offline Thanks Meter: 8 | but please remember the big problem is unit cant detected by pc. its only red blink 4 times. 1_234.. Thanks to Zakiyyboss for the video... |
06-16-2010, 00:18 | #47 (permalink) |
Cheater -Don't Deal with him- Join Date: Dec 2006 Location: Riyadh saudia
Member: 407564 Status: Offline Thanks Meter: 141 | i have soloution this and much mobile i done u open and motherboard put in the thiner or cleaner it take time like 12 hour must u dip in the thiner then put out then ur problem solved b4 u do this 1st u put the mic or camera then do it 100% i done much mobile |
06-17-2010, 12:00 | #48 (permalink) | |
Freak Poster Join Date: Mar 2005
Member: 126801 Status: Offline Thanks Meter: 23 | Quote:
after you try all the software and still not working it means need hardware repair. reheat the PMIC or replace it thats only the simplest solution and sure it will work many times i did the same thing | |
06-18-2010, 00:46 | #51 (permalink) |
Crazy Poster Join Date: Apr 2009 Location: ENGLAND
Member: 1015559 Status: Offline Sonork: IT-Specialist Thanks Meter: 2 | Brother motherbord usb meaning is Back side of Computer Usb port which is 4 ports, anyway... may be your charging point of phone also not work or needs to fix, may be cable you using that cable not suitable for proper connection, you needs to check first hardware side of phone, because as you said RED LIGHT is blinking that means there is hope for recover your phone, anyway if you get solution so please post here so we can get advantage from your experiance. good luck |
06-23-2010, 09:13 | #52 (permalink) | |
here is the picture where can you find the PMIC i repaired many times in this problem. Or it might im so lucky to repair this problem I hope this can help you. thanks | |
06-23-2010, 18:38 | #53 (permalink) | |
Freak Poster Join Date: Oct 2002 Location: Fortaleza/Ce-Brasil Age: 56
Member: 16845 Status: Offline Thanks Meter: 34 | many same question, many wrong answers. Quote:
is there many wrong answers to same problem. please, this is a big problem. I had a 8310 and not solved. I have a 8900 and I have not solution. IT IS THE PROBLEM: USB CAN'T DETECT BY PC. Clear pcb: I made. low power in usb: I made external power suply to usb. I made all. I lost many times with this problem. | |
01-09-2011, 14:34 | #57 (permalink) |
Junior Member Join Date: Dec 2007
Member: 662191 Status: Offline Thanks Meter: 1 | I think this will work because my BB9000 worked when i gave to service, they did some cleaning, but it would show the same red light blinking after 2 hours or so..it happened with 2 times at different service centers..what both did was a few minutes of thinner cleaning, so if u put it in long hours it SHOULD work.. Last edited by sivankls; 01-09-2011 at 14:42. |
02-08-2011, 19:06 | #59 (permalink) |
Junior Member Join Date: Sep 2005 Age: 46
Member: 178023 Status: Offline Thanks Meter: 3 | through my experience,it happened a lot in 9000...all hardware that can be change already replaced...the next step to do is to remove d cpu or flash ic.....and replace.i m trying it and will advise later....pls contact me @ [email protected] thx |
Help PLEASE, BlackBerry 8900 red blinking! | trte-mrte | BlackBerry (RIM) | 2 | 03-02-2010 21:25 |
blackberry 9000 red blinking | hi_tech007 | BlackBerry (RIM) | 2 | 02-03-2010 10:16 |
Bb 9000 red blinking !!! | zakiyyboss | BlackBerry (RIM) | 0 | 12-01-2009 21:55 |
Blackberry shows red blinking lamp | indoponzel | BlackBerry (RIM) | 5 | 06-21-2009 05:33 |
blackberry 8100 red blink | eumore79 | BlackBerry (RIM) | 3 | 11-20-2008 06:40 |
