Blackberry 9000 red light blink only can not turn on Hi guys i m have blackberry 9000 only red light blink can not turn on can not connect to the pc what to do how do i flash this phone what will be the problem can some one help me what to do? Thanks. |
anyone knows what to do? |
1. Resold charging jack or Replace charging jack 2. Erase with MFI Multi loader 3. Update latest Firmware with application loader If any issue post me reply ..:: X.Ram ::.. |
Hi Bro...i have some problem. My Bold 9000 cannot On. only red light blinking. when i try erase with MFI...PIN detect 0000000 end FAIL. i try reflash with apploader without battery...(PIN UNKNOW) still unable n fail. |
And then you erase firmware and reload. |
Use the mml (check both boxes)connect phone without battery, when done do not unplug.. install battery click the ball then type START... unplug shut down mml open bb desktom manager reload OS.. |
hello, any body help how how to use MML ??? |
Use the search function there is a sticky on it.. |
Hi Bro...i have some problem. My Bold 9000 cannot On. only red light blinking. iam also change charging jack but still same |
Use the mml (check both boxes)connect phone without battery, when done do not unplug.. install battery click the ball then type START... unplug shut down mml open bb desktom manager reload OS.. Quote:
