BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
06-29-2011, 05:18 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: sri lanka/thailand/maldives Age: 44
Member: 283763 Status: Offline Thanks Meter: 102 | blackberry 9000 red light only i have bb9000 phone, if power on the phone display top red light blink only , i have no idea for this fault , any idea pl thanks |
06-29-2011, 05:30 | #2 (permalink) |
No Life Poster Join Date: Jul 2007 Location: Vancouver BC & Kathmandu Nepal
Member: 538410 Status: Offline Sonork: 100.1590750 Thanks Meter: 193 | the check the battery and connect it to pc and check does the driver for blackberry smartphones detected or not if it is detected then restore or update the firmware |
The Following User Says Thank You to robean For This Useful Post: |
06-29-2011, 07:01 | #3 (permalink) |
Freak Poster Join Date: Jun 2011 Location: North Korea
Member: 1589313 Status: Offline Sonork: .. Thanks Meter: 34 | flashing guide http://forum.gsmhosting.com/vbb/f489...sy-way-895988/ for firmware http://forum.gsmhosting.com/vbb/f489...models-490374/ |
06-16-2012, 10:23 | #5 (permalink) |
No Life Poster Join Date: Oct 2009 Location: banglore
Member: 1141761 Status: Offline Sonork: 100.1618159 Thanks Meter: 346 | blackberry solution for blinking red light 100% working blinking red light solution for all blackberry 1. download blackberry master control program and install it 2. download CFP_3.9.0.175.exe keep on desktop 3. open master control program and click on setting wheel on left hand side and in enable protected control type BrickBerry same as it is here 4. right click on alien face cfp button at left hand side. 5. below in cfp option (rim command-line program (cfp) executable ) select the cfp which you copied on desktop. 6. connect your bb without battery on top command-line interface (CLI) select wipe tick mark the empty box next to execute and press execute it will take 10 to 12 minutes after it finish disconnect your bb install a battery and wait for few minutes let the phone do its job. let the bb master control be open.......... now the trick is to load os 1. In bb master control on right hand side below right click on apploader it will loader/nojvm connect your phone follow the instruction thats it you have done the job.. please write me if you have any doubt or error thanks nasir |
BLUE light | Delfo | Nokia Hardware & Hardware Repair | 8 | 09-20-2002 04:28 |
5110/6110 after unlocking see only network to which it was locked and ... | 2M | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 07-25-2000 00:51 |
Only MAX232 ??? | AMIGO | Nokia Hardware & Hardware Repair | 7 | 04-12-2000 09:41 |
£20 only NOKIA 51xx/61xx sp locks 1,2,3,4 removed | spterminator | Main Sales Section | 0 | 08-08-1999 05:08 |
i can unlock nokia 51xx/61xx sp locks 1,2,3,4 £40 each £30 bulk for u.k only | spterminator | Main Sales Section | 0 | 08-01-1999 05:46 |
