BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
03-09-2009, 15:55 | #1 (permalink) |
Freak Poster Join Date: Oct 2006 Location: South Africa Age: 48
Member: 372599 Status: Offline Thanks Meter: 41 | Blackberry 9000 unlock succesfull but can not make call. need help pls. |
The Following User Says Thank You to bakhshalvi007 For This Useful Post: |
05-21-2009, 15:27 | #6 (permalink) | |
Freak Poster Join Date: Jul 2006 Location: Ghana-Accra
Member: 311615 Status: Offline Sonork: 100.1591575 Thanks Meter: 72 | Take time and do it 100% working Quote:
Procedure Step 1 : Ensure the Blackberry Desktop Manager is installed using Blackberry Internet Service, and not Blackberry Enterprise Server. If you are unsure, it would probably be a good idea to uninstall the Desktop Manager and start again. If you don't have the CD that came with your Blackberry, the Software can be downloaded here. Step 2 : Download the file policy.bin and save it in your Blackberry installation directory (C:\Program Files\Research In Motion\BlackBerry). Step 3 : Wipe your Blackberry, creating a backup if necessary. Select Options/Security/Wipe on the Device. If this option is unavailable, you may have to install the latest software on your Blackberry. You need to Download and install the latest OS for your device. Connect your device, open the Desktop Manager, select Application Loader, and follow the prompts. Step 4 : Close the Desktop Manager if it is open. Step 5 : From the Windows XP Start Menu select Run..., and at the prompt type regedit. In the tree on the left hand side, navigate to: HKEY_Current_Users\Software\Research In Motion\BlackBerry\PolicyManager Right-Click the Policy Manager Folder and select New/String Value. Name the value Path. Now, Double-Click the Path Subkey and set Value Data to: C:\Program Files\Research In Motion\BlackBerry\policy.bin Step 6 : Open the Desktop Manager. Step 7 : Connect the Device. Verification Once complete, the Options/Security screen on your Blackberry should not contain references to an IT Policy, you should now be able to change all settings (including password prompts), and install Third Party Applications. | |
The Following User Says Thank You to Abishalom For This Useful Post: |
6265 network but can not make call | MUTUAL | Nokia CDMA | 1 | 10-27-2009 14:47 |
HTC exca 100 cant make call... need help pls. | dmaetrey | HTC & Smartphones ( WM Without Touch) | 0 | 08-24-2009 04:16 |
NEXTEL Blackberry 7100i not make calls, PLEASE HELP ME!!! | fernandohabert | BlackBerry (RIM) | 13 | 12-26-2008 19:19 |
7600 can send SMS but can not make a call | dennt | Griffin | 7 | 04-05-2004 23:58 |
