Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > BlackBerry (RIM)
BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs.
Old 07-15-2012, 15:35   #1 (permalink)
Member: 1783516
Blackberry 9300 error 507 after loading os
Hi There, I hope somebody can help with this.
I have nuked and wiped my Blackberry 9300 many times and tried to install latest system and others with:
loader
loader /nojvm
MCP
BBSAK
9300-500-B1440-TelefonicaInstaladorRapido
With loader the system seems to load but when re-booting to load applications shows error 507 but continues to load applications.
When finished, booting goes to 75% and reboots a few times then boot bar goes to end, waits then gives error 200.
Then go into MCP and directory lists all applications loaded - seems OK.
cfp INFO gives
Device Info:
PIN: 276992e0
Bootrom Version: 5.15.0.6
Hardware ID: 0x04000F07 RIM BlackBerry Device
HW ID Override: None
Metrics Version: 6.16
Build Date: Jun 12 2010
Build Time: 11:14:13
Build User: ec_agent
Security: Enabled
Supported Options: 0x00000001
Drivers: 0x00000004
Processor: 0x00000001
LDR Blocks: 0x5C0259B4
Bootrom Size: 0x00020000
External MCT/HWV: Enabled
Boot Mode: N/A
Boot OS Count: N/A
HWV:
Board Revision 0001 - 0x0F
CPU Version 0002 - 0xD8
SW Compatibility 0003 - 0x01
POP Revision 0004 - 0x13
Power Mgt Hardware 0007 - 0x2F
POP Security 000B - 0x01
GPS 000C - 0x06
ROM MASK Version 000D - 0x09
Hearing Aid Compat 0037 - 0x01
WCDMA Band supported 003B - 0x02
BSIS support 0041 - 0x01
Mem Config Table (ver 1.24):
Flash Chip: blocks 0-2000, Chip 0, Sub 0
Bootrom: blocks 0-0
OS Dynamic: blocks 2-????
FS Dynamic: blocks ????-1983
OS NV: blocks 1984-2000, total 17
RAM Chip: 0xB8000000-BFFFFFFF, Bank Size 16777216
RAM Chip: 0xC0000000-C7FFFFFF, Bank Size 16777216
CRC: 0xBA75E7C4
Mem Config Table (ver 1.24) (actual):
Bootrom: blocks 0-0
OS Fixed: blocks 2-189
UMP Fixed: blocks 190-291, total = 102
FS Fixed: blocks 292-1983, total = 1692
CRC: 0x5DF2AB24
Flash:
Number of chips: 1
Flash ID: NAND blocks 0-2000
Device ID: 64
Vendor ID: 32
Version ID: 49
Total Size: 250.1 MB
Memory Map:
NAND Blocks: 2001 * 128 Kb
RAM Base: 0xB8000000
IRAM Base: 0x5C000000
OS Range: 2 - 189
File System:
Memory Map:
292 - 1983
Sectors: 1692
Branding:
VendorID: 142
OS Version: 6.6.0.236
Metrics Version: 3.18
FS Code Version: 10.0.0.0
FAT Code Version: 2.33
Package Version: "6.6.0.236"
Build Date: Aug 5 2011
Build Time: 03:02:07
SV Number: 27
OS Address: 0xB8000000-0xB9765FE3
App Start: 0xB88C9A1C
Companion Binary: 0.0.0.0
RAM usage: 0xBE9FFFFC-0xBF4EFFFC
IRAM End: 0xD0F90B0C
DSP ROM2 Address: *not present*
OS Extended Addr: 0xB91D0A1C
LDR Blocks: 0xB92B8284
API Checksum: 0x00000000
JumpTable (<3): 0xB8000388
JumpTable (>2): 0xB8002D24
Radio Code: Janus radio code linked
OS API Version: 149.3
STP Protocol Ver: 5.226.4 (release OS)
HWV:
Board Revision 0001 - [0x01 - 0xFF], 0x01
POP Revision 0004 - [0x00 - 0xFF], 0x01
CPU Version 0002 - [0xD7 - 0xFF], 0x01
ROM MASK Version 000D - [0x09 - 0x09], 0x01
SW Compatibility 0003 - [0x00 - 0x01], 0x01
Power Mgt Hardware 0007 - [0x2F - 0xFF], 0x01
POP Security 000B - [0x00 - 0xFF], 0x01
Version Table:
STP protocol version: 5.226.4
BlockFS API Version: 10.0.0.0
USB driver version: 02.11
Bugdisp RTAS key: 1.0
STP RTAS key: 1.0
NVSIG RTAS key: 1.0
FAT FS Version: 2.33
Block map version: 2.17
NDK ABI version: 0.1
WLAN radio version: 4.3.0.97
Kernel Version: 2.0.0.431
Metrics Version: 1.1
Build Date: Jul 26 2011
Build Time: 01:15:34
Build User: SCM
App:
Version: 6.0.0.668 (0x0600029C)
Metrics Version: 1.7
Build Date: Sep 8 2011
Build Time: 10:36:07
Build User: RIM
Memory Map: 0xB88C9A1C-0xB91D0A1B
App c_main: 0xB8BFA6AC
JumpTable (<3): 0x00000000
JumpTable (>2): 0x00000000
AppFSVersion: 3.0.0.0
AppFSSize: 0x3200000
RAM Map: 0xBD100000-0xBEA00000
IRAM Map: Unused
App Type: JVM
UMP:
Size: 3216064 bytes, blocks 190-214, offset 0
Size: 10076860 bytes, blocks 214-291, offset 70948
Can somebody help me to fix this please?
Is it hardware problem? If so what is the fix.
Thank you for your help and advice.
Old 07-15-2012, 15:53   #2 (permalink)
inside-d-saul's Avatar
Member: 581626
use this and tip factory reset , driver must be installed
Old 07-15-2012, 17:12   #3 (permalink)
Member: 1783516
Thank you for your advice.
I have OS installed. Which driver must be installed?
Results are that factory reset wiped data.
When rebooted, bar went to 100% then stopped and gave error 200.
Here is the section of the error log where the failure seemed to occur:
guid:0x9C3CD62E3320B498 time: Sun Jul 15 16:23:01 2012 severity:1 type:3 app:Java Exception data:
RuntimeException
ApplicationRegistry.waitFor(0x5f3578d801ffd426) timeout
net_rim_cldc-10(4E68CC9F)
ApplicationRegistry
<private>
0x538C
ApplicationRegistry
waitFor
0x5243
ApplicationRegistry
waitFor
0x51AE
net_rim_cldc-21(4E68CC9F)
ProtocolDaemon
getInstance
0x8829
net_rim_tac(4E68CCFA)
TunnelAllocatorImpl
start
0x4B5F
Registration
tacMain
0x2C35
ServiceStartup
main
0x2C57
RuntimeException
ApplicationRegistry.waitFor(0x1c1f298273a93a9b) timeout
ApplicationRegistry
<private>
0x538C
ApplicationRegistry
waitFor
0x5243
ApplicationRegistry
waitFor
0x51AE
net_rim_cldc-26(4E68CC9F)
Proxy
getInstance
0x7B90
net_rim_os-9(4E68D170)
TimeSyncImpl
<init>
0xC2E4
TimeSyncImpl
TimeSyncMain
0xC26C
net_rim_os-8(4E68D170)
ServiceStartup
libMain
0x9805
RuntimeException
ApplicationRegistry.waitFor(0x6ebc3d82c4655357) timeout
ApplicationRegistry
<private>
0x538C
ApplicationRegistry
waitFor
0x5243
ApplicationRegistry
waitFor
0x51AE
net_rim_cldc-8(4E68CC9F)
LowMemoryManager
<private>
0x488B
LowMemoryManager
recoveryNeeded
0x48FE
ApplicationManagerImpl
<private>
0x2C3B
<private>
0x28CB
<private>
0x2D91
<init>
0x3C03
net_rim_app_manager(4E68CCF9)
ApplicationManagerApp
main
0x2F
guid:0x97C9F5F641D25E5F time: Sun Jul 15 16:23:01 2012 severity:0 type:2 app:System data:VM:+BORK
guid:0x97C9F5F641D25E5F time: Sun Jul 15 16:23:01 2012 severity:0 type:2 app:System data:App Error 200
guid:0x97C9F5F641D25E5F time: Sun Jul 15 16:23:01 2012 severity:0 type:2 app:System data:Application Manager threw ApplicationRegistry.waitFor(0x6ebc3d82c4655357) timeout
guid:0x97C9F5F641D25E5F time: Sun Jul 15 16:30:36 2012 severity:0 type:2 app:System data:VM: 600001 gc=0 idle=0 native=net.rim.device.internal.system.InternalServ ices.catastrophicFailure
In BBSAK I loaded the os again which seemed to load OK.
When it rebooted it went to the 75% loaded then restarted loop.
I then did another factory reset and it wiped data then went back in the loop.
Anything else I can try please?
Thanks again
Old 07-15-2012, 17:21   #4 (permalink)
.::V!K@$H::.'s Avatar
Member: 1236722
Sonork: 100.1601546
contact me on yahooo
Old 07-16-2012, 01:40   #5 (permalink)
Member: 896483
try this nuke then wipe 2 x for any error, works for me
Old 07-16-2012, 03:21   #6 (permalink)
Member: 1500835
try this one boss
Old 07-17-2012, 21:16   #7 (permalink)
Member: 1783516
Thanks for the advice.
Unfortunately it made no diffrence.
Any other advice would be much appreciated.
Old 07-17-2012, 21:26   #8 (permalink)
Member: 1016920
Sonork: love_bird
change boot ic and dan flash it
Old 07-18-2012, 01:31   #9 (permalink)
Member: 1496671
bro... i hope you are not downgrading it... just try flashing with the latest version
BlackBerry Handheld Software v6.0.0.2921 (Asia) ... hope your problem will solved.
https://swdownloads.blackberry.com/D...8866B403.node1
Old 07-18-2012, 09:04   #10 (permalink)
Gsm_Team's Avatar
Member: 1720781
Sonork: 100.1614209
flash with mfi loader first,it will erase your corrupted os then load rapid,problem will be fix.
Old 07-18-2012, 09:40   #11 (permalink)
R.Nasir.Ali's Avatar
Member: 1141761
Sonork: 100.1618159
Arrow try this method
try this ::all bb software solutions 2 by nasir.rar
after nuke and wipe load mfi9300.exe just connect and double click on loader
its here :MFI9300.EXE
Old 07-18-2012, 11:15   #12 (permalink)
Shakeel_pattoki's Avatar
Member: 437195
Sonork: sonork is spam!
U might to download latest OS.
Old 07-20-2012, 12:41   #13 (permalink)
Member: 1783516
Thanks for your replies.
I eventually got it to start up but when I removed the battery and replaced it went back to error condition.
What is location of the boot ic as I suspect it needs reflowing?
Thanks again
where to find a working program all they have some errors ?? fondas Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 12-12-2012 12:26
5110 5.24 locked all 4 locks after unlocking... MCG Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 03-07-2000 21:24
The multiple errors of Winlock ... ??? Genata Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 09-20-1999 19:12
NEW ERICSSON A1018 £60 SIEMANS C25 £60 + LOADS MORE MILLENNIUM-INTERNATIONAL Main Sales Section 0 08-31-1999 18:54
error (1002) simlock3.dll winopen fondas Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 08-28-1999 15:57
Page generated in 0.36398 seconds with 11 queries
