Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > BlackBerry (RIM)
BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs.
Old 11-21-2009, 19:49   #1 (permalink)
urecel's Avatar
Member: 520810
Blackberry 9530 cant flash
Soft used
9530AllLang_PBr4.7.0_rel120_PL4.0.0.107_A4.7.0.85. exe
and Stop flashing.
Battery Full.
Old 11-22-2009, 06:04   #2 (permalink)
Member: 175791
Change cable .
Old 11-23-2009, 00:20   #3 (permalink)
urecel's Avatar
Member: 520810
are you sure?
Because with this same cable i flash a BB 8220 rigth.
Old 11-23-2009, 03:07   #4 (permalink)
Member: 896483
flash without bat, whwn init process put the bat (full charge the bat)
Old 11-23-2009, 03:09   #5 (permalink)
Crazy Poster
Member: 580032
try many times man i had the same problem i did it many times and my phone is working now
Old 11-23-2009, 03:36   #6 (permalink)
urecel's Avatar
Member: 520810
Not working friend,
any more?
Thanks
Old 11-23-2009, 04:34   #7 (permalink)
mujahid_ali's Avatar
Member: 547967
Originally Posted by urecel View Post
Not working friend,
any more?
Thanks
Hello
try this reinstall drivers reinstall Desktop manager and then try to do that as u know u phone stop working at Initialize step so it mean problem in connection .
Try and Post Result.
Thanxs
Old 11-23-2009, 04:35   #8 (permalink)
lusandi's Avatar
Member: 383961
Not working friend,
any more?
Thanks
problem it cable believe or not iface same prblem
Old 11-23-2009, 13:32   #9 (permalink)
urecel's Avatar
Member: 520810
Hi this is last error in conection, i get it
Old 11-23-2009, 13:51   #10 (permalink)
Rise's Avatar
Member: 39022
Sonork: 1575244
@urecel
listen dear, putt out battery and try to flash.
when software show's "waiting for device initilization"
then put battery and see screen if screen not shows on then power on manually.
and it should be working
these procejure do with orignal cable or orignal nokia cable.
if not then change ur pc.
sometime 1 pc not communicate.
u should must have 2 pc's or 2 windows in ur pc.
then u can confirm it whats actual problem.
Old 11-23-2009, 14:00   #11 (permalink)
sairat's Avatar
Member: 337837
Mate one & only one solution just charge your battery full & then try again yesterday i solve this problem
>>> BlackBerry 9530 Firmware <<< RNC_EBM BlackBerry (RIM) 11 03-01-2013 09:11
Blackberry 9530 verizon cant enter mep urecel FuriouS TeaM Products 7 03-12-2010 11:49
I NEED BlackBerry 9530 BlackBerry Firmwares dharmdev FuriouS TeaM Products 3 04-07-2009 12:50
I NEED BlackBerry 9530 BlackBerry Firmwares dharmdev BlackBerry (RIM) 0 04-07-2009 09:22
Page generated in 0.28053 seconds with 11 queries
