Blackberry 9900 Internal Memory Problem Hi, guys i got a bb 9900 with internal memory problem, always formating the internal memory and after i reset the phone the internal memory is damage again. sometimes is stuck on 75% loading bar. I nuke the phone, use fast installer and loader, and i cant repair the internal memory? any help with this please? thank you |
the phone is ok, and all is working except the internal memory, but each time I reset the phone, sometimes is stuck on 75% loading bar, please help |
I've got the same problem , any clue ?? |
is internal imgae prob and is 100% software prob to need to use blackberry erase exe for this then load os is working 100%.............................................. ................ |
erase.exe [QUOTE=naveedshah2;9106243]is internal imgae prob and is 100% software prob to need to use blackberry erase exe for this then load os is working 100%.............................................. ................[/QUOTE what kind of erase.exe? already try nuke, wipe -f or -i, no luck |
Not 100% in software, If internal memory danaged phone will always hang on blACKBERRY loading bar. can be solved by replacing the san disk memory on top of pc. you can rehot maybe fix. |
answer Quote:
for info go to SoluPro - Solupro Blackberry maybe this info can help you, bro |
dan brp duit? |
Order & License - Solupro Blackberry |
how making to be member of the forum |
Username:????????? Password: ???????? wbr ;tejaram |
Password: solupro |
can be solved by replacing the san disk memory on top of pc.http://www.sdra.info/a17.jpghttp://www.sdra.info/k3.jpg |
