BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
06-16-2012, 10:43 | #2 (permalink) |
No Life Poster Join Date: Oct 2009 Location: banglore
Member: 1141761 Status: Offline Sonork: 100.1618159 Thanks Meter: 346 | blackberry solution for blinking red light 100% working blinking red light solution for all blackberry new and tried on 100s off bb modules success on all 1. download blackberry master control program and install it 2. download CFP_3.9.0.175.exe keep on desktop 3. open master control program and click on setting wheel on left hand side and in enable protected control type BrickBerry same as it is here 4. right click on alien face cfp button at left hand side. 5. below in cfp option (rim command-line program (cfp) executable ) select the cfp which you copied on desktop. 6. connect your bb without battery on top command-line interface (CLI) select wipe tick mark the empty box next to execute and press execute it will take 10 to 12 minutes after it finish disconnect your bb install a battery and wait for few minutes let the phone do its job. let the bb master control be open.......... now the trick is to load os 1. In bb master control on right hand side below right click on apploader it will loader/nojvm connect your phone follow the instruction thats it you have done the job.. please write me if you have any doubt or error thanks nasir if gives you error again go to step 6 select nuke and then wipe after this if says error dont cancel the procedure just disconnect the phone remove the battery re insert and wait untill the phone finish then connect the phone and press retry |
8850 lights went darker...help pls... | jsp_m | Nokia Hardware & Hardware Repair | 3 | 04-19-2004 12:00 |
BLUE light | Delfo | Nokia Hardware & Hardware Repair | 8 | 09-20-2002 04:28 |
GSM light in your Phone | GM | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-28-2001 16:15 |
NOKIA 3210 V6.0 Nothing on display - just light | mobitech | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 02-13-2001 23:49 |
Home Made Infra-red adapter... | WildSwan | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-30-2000 16:51 |
