BlackBerry Bold 9900 Auto-Wipe,Nuke and Loader This will fix most of the software related problems on a 9900 for example: stuck on 75% reboot (fixed mine) it works kinda like http://forum.gsmhosting.com/vbb/f489...cript-1445534/ except it won't use any 'Nal Loader' and the full os install is done by apploader BlackBerry Bold 9900 Auto-Loader.exe will -Ask admin acces just to avoid dealing with file permission when deleting Vendor.xml -Prompt to press any key when you connected your blackberry -WIPE your device's filesystem & installer partition -NUKE your device including the os -LOAD the bold 9900 system -Remove Vendor.XML -Run Apploader to load the full os so make sure you have the correct os installed this file is just a simple sfx archive which extract the files to a temp directory and then execute the script and when done remove the temp dir if want to take a look at the script just rename .exe to .rar Archive contents: bb9900autoloader.bat, CFP.exe, rim0x07001204.sfi BlackBerry Bold 9900 Auto-Loader.exe |
if you extract the archive & remove 'CFP.exe -u LOAD rim0x07001204.sfi' from bb9900autoloader.bat and make sure you have the correct os for your device installed on your pc it will also work on devices other than the 9900 |
Yesterday, at 10:50 you had allreadry read my post, and i had dericted you to go wright post.I had solved so many 9810 by using "all in one script ".it's 100% ok.except in 9220 & 9320 it's work fine in all previous model also. http://forum.gsmhosting.com/vbb/f489...cript-1445534/ |
blackberry 9900 red blink show password 10 left but password not accept how to solv this problem any body help me plz |
