Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > BlackBerry (RIM)
BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs.
Old 05-23-2013, 21:13   #1 (permalink)
Member: 1827848
Thanks Meter: 5
BlackBerry Bold 9900 Auto-Wipe,Nuke and Loader
This will fix most of the software related problems on a 9900 for example: stuck on 75% reboot (fixed mine)
it works kinda like NUKE, WIPE, NAL and OS all in one script except it won't use any 'Nal Loader' and the full os install is done by apploader
BlackBerry Bold 9900 Auto-Loader.exe will
-Ask admin acces just to avoid dealing with file permission when deleting Vendor.xml
-Prompt to press any key when you connected your blackberry
-WIPE your device's filesystem & installer partition
-NUKE your device including the os
-LOAD the bold 9900 system
-Remove Vendor.XML
-Run Apploader to load the full os
so make sure you have the correct os installed
this file is just a simple sfx archive which extract the files to a temp directory and then execute the script and when done remove the temp dir
if want to take a look at the script just rename .exe to .rar
Archive contents: bb9900autoloader.bat, CFP.exe, rim0x07001204.sfi
The Following 3 Users Say Thank You to delour For This Useful Post:
Old 05-24-2013, 14:44   #2 (permalink)
Member: 1827848
Thanks Meter: 5
if you extract the archive & remove 'CFP.exe -u LOAD rim0x07001204.sfi' from bb9900autoloader.bat and make sure you have the correct os for your device installed on your pc it will also work on devices other than the 9900
Old 02-11-2014, 03:24   #3 (permalink)
Deni's's Avatar
Member: 1800628
Thanks Meter: 494
-Remove Vendor.XML
do you have for 9810?
Old 02-11-2014, 05:16   #4 (permalink)
Member: 25662
Thanks Meter: 186
Dear Deni's again you r asking for 9810?
Yesterday, at 10:50 you had allreadry read my post, and i had dericted you to go wright post.I had solved so many 9810 by using "all in one script ".it's 100% ok.except in 9220 & 9320 it's work fine in all previous model also.
Old 03-12-2014, 06:24   #5 (permalink)
SHAAN MOBI's Avatar
Member: 1537728
Sonork: 100.1646222
Thanks Meter: 15
blackberry 9900 red blink show password 10 left but password not accept how to solv this problem any body help me plz
Page generated in 0.23874 seconds with 7 queries
