Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > BlackBerry (RIM)
BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs.
Old 06-02-2011, 11:46   #1 (permalink)
Arshu007's Avatar
Member: 1476028
Sonork: 100.1625985
Thanks Meter: 114
How to Disable Security Lock BlackBerry 8310
Any Solution Pls ............
Old 06-02-2011, 11:49   #2 (permalink)
adityajha's Avatar
Member: 1183572
Thanks Meter: 203
type blackberry as password 10 times phone will be reset by self.
Old 06-02-2011, 11:55   #3 (permalink)
Arshu007's Avatar
Member: 1476028
Sonork: 100.1625985
Thanks Meter: 114
bro code already i change , i need How to disable security code
No option Disable on phone ...
Old 06-02-2011, 12:47   #4 (permalink)
/FAISAL/'s Avatar
Member: 781860
Thanks Meter: 203
Method One
Method 1: IT Policy Removal (Preferred)
If you have any 8xxx or 9xxx device the best method for removing IT policy is to update it to OS 4.3 or higher (if possible) and you can use JL_Cmder's "resettofactory" command to remove ALL IT policy, Firewall restrictions and Application Permission settings. After you've upgraded to OS 4.3 or higher, simply backup the device using Desktop Manager, close Desktop Manager, then run JL_Cmder and execute the "resettofactory" command. The device will do a security wipe of the device; (meaning wipe your data but leave the OS, DO NOT use the "Wipe" command in JL_Cmder) then reboot leaving the OS, 3rd party apps but no data AND, best of all, NO IT policy whatsoever. When you're done, simply restore your backup and you're good to go with no policy or locked firewall. You can downgrade back to the old OS if you desire, too.
Download JL_Cmder from this link: JL_Cmder - BlackBerry Forums Support Community
If your 7xxx or 8xxx device is running OS 4.2 or lower (look in Options >About) and you can't upgrade it to OS 4.3 or higher you will NOT be able to use method 1 above and you will need to use method #2 below:
Method Two
Step 1
Ensure the Blackberry Desktop Manager is installed using Blackberry Internet Service, and not Blackberry Enterprise Server. If you are unsure, it would probably be a good idea to uninstall the Desktop Manager and start again.
If you don't have the CD that came with your Blackberry, the Software can be downloaded here. BlackBerry Software Site
Step 2
Download the file policy.bin Download Here. and save it in your Blackberry installation directory (C:\Program Files\Research In Motion\BlackBerry).
Step 3
Wipe your Blackberry, creating a backup if necessary. Select Options/Security/Wipe (Newer 4.2 OS Devices Goto Options/Security Options/General Settings/Wipe) on the Device.
If this option is unavailable, you may have to install the latest software on your Blackberry. You need to Download and install the latest Desktop Manger Software, then the latest Handheld Software. Connect your device, open the Desktop Manager, select Application Loader, and follow the prompts.
Step 4
Close the Desktop Manager if it is open.
Step 5
From the Windows Start Menu select Run..., and at the prompt type regedit. In the tree on the left hand side, navigate to:
HKEY_Current_Users\Software\Research In Motion\BlackBerry\PolicyManager
Right-Click the Policy Manager Folder and select New/String Value. Name the value Path. Now, Double-Click the Path Subkey and set Value Data to:
C:\Program Files\Research In Motion\BlackBerry\policy.bin
Step 6
Open the Desktop Manager.
Step 7
Connect the Device.
The Following User Says Thank You to /FAISAL/ For This Useful Post:
Old 06-03-2011, 07:55   #5 (permalink)
Arshu007's Avatar
Member: 1476028
Sonork: 100.1625985
Thanks Meter: 114
Originally Posted by /FAISAL/ View Post
Method One
Method Two
Step 1
Step 2
Step 3
Step 4
Step 5
Step 6
Step 7
Connect the Device.
phone version v4.5.0.174
i try to Method 1: IT Policy Removal (Preferred)
but note complete ......
Any Solution ....
Old 06-03-2011, 09:45   #6 (permalink)
Arshu007's Avatar
Member: 1476028
Sonork: 100.1625985
Thanks Meter: 114
my 2end Blackberry 8310 Success to Method 1
phone v4.5.0.55
Method One
Thanks for the Share .....
Old 06-03-2011, 09:47   #7 (permalink)
Arshu007's Avatar
Member: 1476028
Sonork: 100.1625985
Thanks Meter: 114
Any Solution ....
This phone is note done
any solution ......
Old 06-03-2011, 11:42   #8 (permalink)
Member: 532123
Thanks Meter: 7
any solution ......
You can try this soft after install ,follow address : Divice sofware(s) -->wipe divice
already tested ok
The Following User Says Thank You to tvdmd75 For This Useful Post:
Old 06-04-2011, 06:58   #9 (permalink)
Arshu007's Avatar
Member: 1476028
Sonork: 100.1625985
Thanks Meter: 114
Method One
Method Two
Step 1
Step 2
Step 3
Step 4
Step 5
Step 6
Step 7
Connect the Device.
This is a 100000000000% Success Solution
Thanks for The Share Bro
Old 06-04-2011, 12:40   #10 (permalink)
Member: 1499336
Sonork: 1620988
Thanks Meter: 16
best and easiest way of removing I.T policy is using CrackUtil.
Old 03-22-2013, 15:10   #11 (permalink)
FORUM-FON's Avatar
Member: 1832100
Thanks Meter: 63
BlackBerry 8310 How to Disable Security Lock ( IT policy )
Method One
Method Two
Step 1
Step 2
Step 3
Step 4
Step 5
Step 6
Step 7
Connect the Device.
Any Other Solution ....
Old 03-22-2013, 15:12   #12 (permalink)
FORUM-FON's Avatar
Member: 1832100
Thanks Meter: 63
Hey Bro Explain and Share The Link
Old 03-22-2013, 22:26   #13 (permalink)
Member: 1096913
You can remove the ITPolicy using CrackUtil Program, its easy!!! Instal it !!!!!!!!!
Run the program, go to ADVANCE, and follow the instrutions!!!
The Following User Says Thank You to chelov60 For This Useful Post:
Old 03-22-2013, 22:26   #14 (permalink)
Member: 1096913
CrackUtil, this is the program, that you need!!!
Old 03-23-2013, 07:01   #15 (permalink)
Arshu007's Avatar
Member: 1476028
Sonork: 100.1625985
Thanks Meter: 114
BlackBerry 8310 Success Fully Disable Security Lock ( IT policy )
download this - CrackUtil .
CrackUtil.zip
Then Do This Step :
1000% Tested for Me .....
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 11:57
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 18:29
Copy from one 6110 to another Leif Nielsen Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-10-1999 22:36
Page generated in 0.40287 seconds with 9 queries
