Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > BlackBerry (RIM)
BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs.
Old 01-23-2013, 09:46   #1 (permalink)
Member: 1493898
blackberry bold 9900 stuck on loading screen
my blackberry bold 9900 stuck on loading screen
i have tried restoring software twice the firmware load successfuly but after
that also stuck on the same position as it was earlier befor
guyz plz help me to solve this prob...???
Old 01-24-2013, 13:22   #2 (permalink)
Member: 1804175
Thanks Meter: 25
use this tool NUKE, WIPE, NAL and OS all in one script
first nuked ur device and then dual wipe ur device. Done
Old 01-24-2013, 16:32   #3 (permalink)
Member: 1804175
Thanks Meter: 25
or using this tool New Tool Blackberry BBCMD.exe One Kliksilahkan di coba fungsi-fungsi tool BBCDM; *
first nuked ur device and then wipe system ur device. Done..
Old 01-26-2013, 09:36   #4 (permalink)
Moderator
tkowsar's Avatar
Member: 233205
Thanks Meter: 4,886
how much percent its stuck or restart (although there no % count on screen) any idea?
Old 01-26-2013, 09:42   #5 (permalink)
Member: 328688
Thanks Meter: 981
u need full erse + wipe with pbtool if u hve may it help u after flash it
Old 01-26-2013, 09:44   #6 (permalink)
zishhaider's Avatar
Member: 952111
Sonork: I'm not using now.
Thanks Meter: 537
Use quick installer and your problem will be solved....
Old 01-26-2013, 13:20   #7 (permalink)
Member: 1874393
Sonork: 11237
Old 01-27-2013, 12:22   #8 (permalink)
Member: 1384861
Look here broo your Problem Solved
Old 01-27-2013, 12:43   #9 (permalink)
Member: 216705
Thanks Meter: 42
software software software fault...
Old 10-15-2015, 08:21   #10 (permalink)
Member: 2114397
Thanks Meter: 131
bb9900 75% loading solution plzzzzzzz
Old 10-15-2015, 08:35   #11 (permalink)
Member: 2114397
Thanks Meter: 131
i successfully flashed my bb9900 bold now its booting completely
Old 10-15-2015, 13:09   #12 (permalink)
Member: 2114397
Thanks Meter: 131
blackberry bold 9900 stuck on loading screen 1000000000% solution
1 charge your battery
2 download this tool (bb cmd by del_fanfan) link is below
3 install blackberry 9900 firmware download it searching by google
4 run bb cmd by del_fanfan tool
5 connect your bb9900 by usb cable with pc install driver if you are using window7
driver automatically will be install
6 on cmd by del_fanfan tools select WIPE FULL option
7 now your bb9900 is full wipe now you can see just red blinking light no lcd display its mean you successfully wipe your mobile if u can see lcd display after full wipe its mean your mobile not full wipe .
8 after wiping go to C drive where you install bb9900 firmware (c:\program files\common files\research in motion\apploader) and delete the file vendor.xml
9 Plug the device into the PC using the USB cord and make sure BB Desktop Manager is closed
10 RUN apploader now you can see bb9900 commport now just click next next and next bb9900 begin for flashing
11 just sit down be relax after 15 minutes your mobile start. during flashing dont connect any other mobile with your pc
say thanx and reply if you got success
4shared.com - free file sharing and storage - Login
The Following User Says Thank You to atiqmalik For This Useful Post:
Old 10-15-2015, 13:26   #13 (permalink)
Member: 2114397
Thanks Meter: 131
use this link for tools downloading
bb cmd by del_fanfan - Download - 4shared - fanfan del
Old 10-22-2015, 23:27   #14 (permalink)
Member: 1609576
Thanks Meter: 12
Just disable the Built-in Media Storage,95% assurance
Old 11-11-2015, 10:29   #15 (permalink)
Member: 1150328
Thanks Meter: 11
hi, ive wiped os with bb cmd by del_fanfan,
do i reload with bb desktop manager?
Page generated in 0.39359 seconds with 7 queries
