Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > BlackBerry (RIM)
BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs.
Old 01-07-2012, 16:38   #1 (permalink)
y3kt's Avatar
Member: 238127
Sonork: 100.1574867
Thanks Meter: 3,512
BlackBerry Codes Reader/Calculator. My Version!
Hi, i have updated my application to version v1.2.
What's new.
  • Added some text formatting to log window
  • Ability to copy log window to clipboard
  • Now by default it only calculates MEP2 all other MEPS can be calculated if specify
  • Some minor bug fixes
  • Another PRD added now i have 4
Download
The Following 71 Users Say Thank You to y3kt For This Useful Post:
Old 01-07-2012, 18:38   #2 (permalink)
y3kt's Avatar
Member: 238127
Sonork: 100.1574867
Thanks Meter: 3,512
BlackBerry 9900 OS7 Read & Calculate Code OK!
We had installed Desktop Manager 5.01 in that machine, so maybe that explains why it read phone Ok at first time and many times after.
The Following 15 Users Say Thank You to y3kt For This Useful Post:
Old 01-09-2012, 10:37   #3 (permalink)
Member: 234339
Thanks Meter: 19
Thanks buddy but your your need to correct your coding on new phones like 8900 etc . For all users of just for collection just use only the first 8 digits of calculated code for mew meps.
The Following User Says Thank You to Microse For This Useful Post:
Old 01-09-2012, 20:44   #4 (permalink)
y3kt's Avatar
Member: 238127
Sonork: 100.1574867
Thanks Meter: 3,512
I can't get exactly what you mean, if you have any code calculated qith 16 digits and correct code is 8 digits then please, let me know which mep is it so i can correct it in software.
Thanks in advanced!
Old 01-09-2012, 21:04   #5 (permalink)
y3kt's Avatar
Member: 238127
Sonork: 100.1574867
Thanks Meter: 3,512
I have updated application to v1.3
What's new:
  1. Some bugs fixed
  2. Added AUTOPRD function
AUTOPRD function is a feature which allow every user of the software to save PRD - MEP combination for each phone they read the codes from. This way they create a personal database which is useful to calculate codes based on PRD if MEP and PRD are saved.
Users who read a lot of phones can share they databases or send them to me in order to keep future versions updated.
More requested features are on the way, i just need some time
The Following 10 Users Say Thank You to y3kt For This Useful Post:
Old 01-10-2012, 13:50   #6 (permalink)
Member: 1338480
does this support all models of blackberry.. including the latest ones like Bold 9900 and 9930.. ?
Old 01-10-2012, 14:49   #7 (permalink)
y3kt's Avatar
Member: 238127
Sonork: 100.1574867
Thanks Meter: 3,512
All models are supported as long as MEP is known, luck
Old 01-10-2012, 15:31   #8 (permalink)
y3kt's Avatar
Member: 238127
Sonork: 100.1574867
Thanks Meter: 3,512
It is based on sources made public by SiRoYa, with some nice additions not found on that sources, i dont know where avator got it sources from, luck
Old 01-10-2012, 23:41   #9 (permalink)
jfl
Member: 64391
Thanks Meter: 1,253
Wich format is your PRD data base ?
A small contribution
Orange France :
MEP-07723-005 PRD-22578-150
MEP-07723-007 PRD-38627-004
SFR France :
MEP-05277-005 PRD-30001-003
Bouygues Telecom France :
MEP-08918-001 PRD-32136-012
Thanks again for your work (and thanks Syroya)
The Following 2 Users Say Thank You to jfl For This Useful Post:
Old 01-11-2012, 00:44   #10 (permalink)
rogerboogie's Avatar
Member: 103024
Thanks Meter: 588
hi bro , how can i add prd to list of database ?
which format or which program can i use to update the prd list on database i can coolaborate a lot , in nights i have free time
Old 01-11-2012, 14:17   #11 (permalink)
y3kt's Avatar
Member: 238127
Sonork: 100.1574867
Thanks Meter: 3,512
Orange France :
SFR France :
I will think of some way of adding PRD manually to database, thanks for your help.
Old 01-11-2012, 21:51   #12 (permalink)
y3kt's Avatar
Member: 238127
Sonork: 100.1574867
Thanks Meter: 3,512
Hi to all, this is, i think, the last version i will release as i think there is nothing else to be done with this little piece of software.
Today I present v1.4
What's new:
  • Added Bulk IMEI Calculator*
  • Added option to manually add PRD - MEP combination to database**
These features were added as a request from several users and because they were not difficult to implement. As you see unique features not available in paid software (at least publicly known)
With more than 1400 downloads in less than 10 days i hope everybody will enjoy the software.
*Format for Bulk IMEI Calculator is pretty simple, just add as many IMEIS as you want to a simple text file. ONE IMEI PER LINE. All IMEIS must correspond to same MEP.
**Now you can manually add PRD - MEP to database for calculation. Don't worry, even if you repeat same PRD, software will not save it twice to database.
Notice that there could be the case where one PRD will match 2 or more MEP, in this case software will calculate codes for each MEP and user will only have to try one by one until a good one is found.
Many things can be done, i know, but for a free software i think it is enough unless there is just an excellent idea to add and/or i get some free time to spend playing with its code.
Thanks to all who have downloaded the software, and please, if you are amongst those who will use it very much and updates the autoprd database, please share it or at least send it to me so i can keep a list of prd as this could be the reason for a next update.
Link is the same as in first post.
The Following 13 Users Say Thank You to y3kt For This Useful Post:
Old 01-11-2012, 22:14   #13 (permalink)
philzfog16's Avatar
Member: 790617
Thanks Meter: 57
WORKS FINE TESTED ON movistar 9300 spain
1 DEVICE FOUND!
SETTING UP CONNECTION...
DEVICE READY!
IMEI: 3580330
MEP: MEP-06041-009
PRD: PRD-38284-019
MEP2(NCK): 5848715465683078
BlackBerry Codes Calculator by y3kt v1.3
9300 o2 uk
1 DEVICE FOUND!
DEVICE READY!
IMEI: 35631904751
MEP: MEP-06424-002
PRD: PRD-30231-010
MEP1: 2681795881840207
MEP2(NCK): 9557057433927661
MEP3: 1012036657155068
MEP4: 7274802261430478
MEP5: 1336117196526924
The Following 2 Users Say Thank You to philzfog16 For This Useful Post:
Old 01-12-2012, 21:52   #14 (permalink)
Member: 1102520
Sonork: 100.1617999
Thanks Meter: 94
Is this in vb.net??
if yes can you plssssssssssssssssssssssssssssssssssssssssssssssss ssssssssssssssssssssssssssssssssssssssss
share source code as i don't understand the language that siroya published
I will be really pleased
Thanks in advance
Old 01-13-2012, 00:00   #15 (permalink)
y3kt's Avatar
Member: 238127
Sonork: 100.1574867
Thanks Meter: 3,512
The language is the same as was posted, so it would be a good idea for you to start learning some Delphi, luck!
The Following 3 Users Say Thank You to y3kt For This Useful Post:
Seeking for flash nokia 5110 old version (3 version) can exchange for new Tomas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 10-14-2017 20:29
Help: Forgot my 6110 user lock code!! GByte9 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 02-26-2016 14:52
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 12:57
Page generated in 0.43115 seconds with 9 queries
