Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > BlackBerry (RIM)
BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs.
Old 12-09-2009, 18:06   #1 (permalink)
gsmshapon's Avatar
Member: 767368
Sonork: 100.1590347
Thanks Meter: 570
BlackBerry Internet Services Modem use Pc
BlackBerry Internet Services Modem using Pc
A dial-up connection can be made using a BlackBerry phone as a modem. With a BlackBerry connected to a PC or laptop your are able to access the internet through the phone.
This can be realized using the
bluetooth dial-up profile if the phone supports this, or with the USB cable
followingThe following illustrates the steps in Windows XP with Service Pack II to use the BlackBerry as a tethered modem via USB. Successfully tested with the BlackBerry Tour 9630, BlackBerry Storm 9530, BlackBerry Bold 900, BlackBerry Curve 8900, BlackBerry Curve 8300, BlackBerry Curve 8310,BlackBerry Curve 8320,BlackBerry Curve 8330, BlackBerry Curve 8350i, BlackBerry Flip 8220, BlackBerry Flip 8230, BlackBerry Pearl 8100, BlackBerry Pearl 8110, BlackBerry Pearl 8120, BlackBerry Pearl 8130, BlackBerry 8800, BlackBerry 8820 and BlackBerry 8830, BlackBerry 8700.
Start the BlackBerry Desktop Manager and connect your BlackBerry with the USB cable.
On installing the Desktop Manager, the Standard Modem will appear in the Device Manager as follows:
(If the Standard Modem does not appear, re-install the Desktop Manager.)
If the Standard Modem still does not appear, it is necessary to manually add the modem.
Take note of the COM port numbers of the
RIM Virtual Serial Port v2 in the devices under Ports (COM & LPT).
In the Control Panel go to Phone and Modem Options.
Choose to add a New Modem.
Choose to select it from a list.
Select the
Standard 33600 bps Modem.
Select the COM ports that are used for the RIM Virtual Serial Port v2 in the Device Manager.
One or more Standard 33600 bps Modems will appear in the Device Manager.
In the case of using bluetooth to make the dial-up connection a "Standard Modem over Bluetooth" will appear in modem devices.
Open the Properties dialog box by right-clicking the modem in the Device Manger.
Go to the Diagnostics tab.
Click on Query Modem. It should answer with a number of responses.
In the Advanced tab fill in the dial-string in the Extra Initialization Commands.
In this case "internet" is the Access Point Name of the network provider.
Here are some other e
xamples of dial-strings:
Rogers: +cgdcont=1,"IP","internet.com"
Cingular Blue/AT&T: +cgdcont=1,"IP","proxy"
Cingular Orange: +cgdcont=1,"IP","ISP.CINGULAR"
UK Vodafone: +cgdcont=1,"IP","internet"
SwissCom: +cgdcont=1,"IP","gprs.swisscom.ch"
T-Mobile NL: +cgdcont=1,"IP","internet","",0,0
grameenphon: +cgdcont=1,"IP","gpinternet","",0,0
This completes the installation of the modem.
Now the dial-up connection has to be made.
Dial-up Connection
In Control Panel go to Network Connections.
Choose Create a New Connection.
Choose to Connect to the Internet.
Choose to Set up the Connection Manually.
Desktop Manager must be open
>>>>>>1
gsmshapon
The Following 5 Users Say Thank You to gsmshapon For This Useful Post:
Old 12-09-2009, 18:25   #2 (permalink)
gsmshapon's Avatar
Member: 767368
Sonork: 100.1590347
Thanks Meter: 570
p-2
Choose to Connect using a dial-up modem.
If there are multiple modems to choose from, select the modem that connects to the BlackBerry
Choose an
Name for the connection.
Type in the phone number *99#.
Only fill in a User name and a Password if required by the by the network provider.
A new connection is made!
Choose Dial to make a connection (no user name or password entered if not necessary by the network provider).
The connection is being made....
BlackBerry internet model supported
8xxx & 9xxx
GSM SHAPON
The Following 6 Users Say Thank You to gsmshapon For This Useful Post:
Old 12-10-2009, 05:47   #3 (permalink)
gsmshapon's Avatar
Member: 767368
Sonork: 100.1590347
Thanks Meter: 570
Model 710X: Success (Rogers, T-Mobile)
Model 7290: Success (Rogers, AT&T, Cingular, T-Mobile)
Model 7250: Success (Verizon)
Model 8100: Success (T-Mobile)
Model 8700: Success (Rogers, Cingular)
Model 7130e: Success (Verizon, Bell Mobility)
Model 7510/7520/7230/7280/7730/7780/7100i
* BlackBerry 7130c
* BlackBerry 7130e
* BlackBerry 7250
* BlackBerry Curve 8300
* BlackBerry Curve 8310
* BlackBerry Curve 8320
* BlackBerry 8703e
* BlackBerry 8705g
* BlackBerry 8707g
* BlackBerry 8800
* BlackBerry 8820
* BlackBerry 8830 World Edition
gsmshapon
Old 12-10-2009, 07:38   #4 (permalink)
Member: 803701
Thanks Meter: 2
thaxxx..............................good work
Old 12-10-2009, 07:56   #5 (permalink)
sagar_lse's Avatar
Member: 777523
Sonork: 100.1584558
Thanks Meter: 335
thank's brother good sheraing..........
Old 12-22-2009, 08:25   #6 (permalink)
gsmshapon's Avatar
Member: 767368
Sonork: 100.1590347
Thanks Meter: 570
BlackBerry Curve 8300 100% work.............................................. ......
The Following 2 Users Say Thank You to gsmshapon For This Useful Post:
Old 12-22-2009, 09:58   #7 (permalink)
IAMJASONBOURNE's Avatar
Member: 1162191
Thanks Meter: 281
How about we figure out how to get data without a plan.
Old 12-22-2009, 10:17   #8 (permalink)
sagar_lse's Avatar
Member: 777523
Sonork: 100.1584558
Thanks Meter: 335
thank's.........................sir
Old 12-29-2009, 07:32   #9 (permalink)
Member: 803701
Thanks Meter: 2
plz help 8900 internet use ......................................
Old 12-29-2009, 07:47   #10 (permalink)
gsmshapon's Avatar
Member: 767368
Sonork: 100.1590347
Thanks Meter: 570
yes 100% internet model supported.............................
The Following User Says Thank You to gsmshapon For This Useful Post:
Old 01-27-2010, 11:21   #11 (permalink)
gsmshapon's Avatar
Member: 767368
Sonork: 100.1590347
Thanks Meter: 570
any problem blackberry add [email protected]
Old 03-01-2010, 08:42   #12 (permalink)
Member: 950982
Thanks Meter: 18
thanks brother nice work...................go ahead
Old 03-01-2010, 11:11   #13 (permalink)
Registered User
prasad3223's Avatar
Member: 259742
Thanks Meter: 215
why so much of work u get it in desktop manager 5.01 version
Old 03-01-2010, 13:34   #14 (permalink)
vodafoneserver's Avatar
Member: 617174
Sonork: 100.1622609
Thanks Meter: 579
BlackBerry Pearl 8100, error conection........
Old 03-01-2010, 14:52   #15 (permalink)
delower10's Avatar
Member: 890592
Sonork: 100.1581951
Thanks Meter: 4,429
Arrow
Go Standerd Modem Properties and select Advanced tab and change Extra Initialization Commands to (+cgdcont=1,"IP","gpinternet","",0,0 )
Then see Dial-up working
Delower
help bsnl 3g modem use airtel internet trick rajdeepsaw Phone Unlocking Codes & Maps 0 01-26-2010 03:41
Orange extends free blackberry internet service for business customers scutt Off Topic Zone 0 04-13-2009 12:31
coonect 6670 to internet, using pc internet, with the bluetooth SLionheart Nokia Multimedia 2 02-09-2007 10:47
Nokia 6600 uses PC Internet over Bluetooth netguy2000 Bluetooth-Software 4 12-14-2005 18:26
Using SX1 as modem for PC murry E-Gold Based Phones 4 02-03-2005 14:52
Page generated in 0.22855 seconds with 9 queries
