BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
08-12-2013, 15:36 | #1 (permalink) |
Freak Poster Join Date: Jan 2013
Member: 1865815 Status: Offline Sonork: 100.1644854 Thanks Meter: 25 | Blackberry OS10 devices using Autoloader These directions apply to Z10, Q10 and Q5 models. Check your Model Number at Settings > About! (OS 10.1.0.4537 and 10.1.0.4633 have been officially released by BlackBerry and the carriers around the world are beginning to roll it out to users.) 1) For Z10 models 100-1, -2, -3, -4: Download the 10.1.0.4537 OS file here 2) For Z10 models 100-1: Download the 10.1.0.4633 OS file here 3) For Z10 models 100-2, -3, -4: Download the 10.1.0.4633 OS file here 4) For Z10 models 100-2, -3, -4: Download the 10.1.0.4687 OS file here 5) For Q10 models 100-1, -2, -3, -4, -5: Download the 10.1.0.4633 OS file here 6) For Q10 models 100-1, -2, -3, -4, -5: Download the 10.1.0.4687 OS file here 7) For Q5 models, download the 10.1.0.4633 OS file here Remember, this process will totally wipe your device, so the backup is important. Download the file above. Extract it from the ZIP file if it is zipped. If it is a ".rar" file, you will need a WinRar unpacking app on your PC to extract the file. Connect your BlackBerry to the PC. Using Link, do a backup*(see below) of your phone. Locate the downloaded file and run the autoloader (double click on the EXE file) and a black DOS window appears indicating "Connecting to bootrom". The DOS window processes the install, and begins to load the OS. If you have a security passwored, you will be asked to enter it. When the OS loading is complete, your Z10 will reboot. Disconnect from the PC. At this point, I always hold down the top edge power button a couple of seconds and touch RESTART at the bottom right. Reconnect to the PC and perform your restore using BlackBerry Link. Now, you will need to reenter account passwords for email, Twitter, Facebook, etc. *Additional notes: When you backup using Link, you can make one total backup, or divide that backup into three different databases (Setup | Media | App Data). I always break that backup into the three different databases so that I can restore each separately because I have had some issues with a full restore failing in the App database restore, so then I can safely restore only Settings and Media. Remember, this process does totally wipe your device, so the backup is important. Reserve about two hours time for the process... performing the backup and restore takes the longest part of the time. Last edited by Kstillo2000; 08-12-2013 at 17:54. |
The Following 6 Users Say Thank You to joseantonio914 For This Useful Post: |
08-28-2013, 14:45 | #4 (permalink) |
Insane Poster Join Date: Oct 2010 Location: cote d'ivoire
Member: 1410502 Status: Offline Sonork: 100.1645892 Thanks Meter: 27 | Blackberry Z10 STL100-2 ,after update with Autoload-STL100-2-10.2.0.1157.exe,i can't make call, no mobile network connection. i try to update with blackberry link, same problem. i try others autoloaders but the problem still. PLEASE HELP |
09-16-2014, 16:26 | #9 (permalink) |
No Life Poster Join Date: May 2010 Location: India,Tamilnadu-Nagercoil Age: 37
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,374 | |
