Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > BlackBerry (RIM)
BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs.
Old 05-30-2012, 07:11   #496 (permalink)
Member: 1755461
You can follow the instructions below, It might help you:
1.Plug your BlackBerry into your computer via the USB port and open the BlackBerry Desktop Manager program. If you do not have BlackBerry Desktop Manager installed, you need to insert the program disc that came with your BlackBerry when you purchased it. Follow the prompts to install it.
2.Click on the "Device Manager" tab in program window and find which com port on your computer your BlackBerry is installed on. It will be listed as "com" followed by a number (com-3, com-4, etc.). Highlight the com port with the highest number after it.
3.Go to your "BlackBerry" folder in the Desktop Manager and open a file called "QPST." Select "QPST Configuration" from the drop-down menu and click on it. This is the flashing software that your Blackberry uses.
4.Wait for the QPST window to open on your desktop and click on the "Ports" tab at the top of the window. Then click "Add New Port" from the list of options.
5.Choose "Com 4" from the list of options to add the port. Under the "Phone" tab on the QPST screen you will see that your Blackberry device is now detected.
6.Click on the "Start Clients" tab at the top of the screen and then select "Service Programming" from the list of options in the drop-down menu. Click "OK" when prompted to confirm.
7.Scroll through the list of file options in the new window until you come to a file that ends in ".bb." This represents your BlackBerry phone. Highlight and select it. Click "OK" when prompted to confirm.
8.Click on the "Roam" tab at the top of the QPST screen, then click the "Browse" tab. Select your current BlackBerry service provider from the list of options and then click the "Write To Phone" tab at the bottom of the window. Your BlackBerry will now be flashed.
Old 06-05-2012, 10:06   #497 (permalink)
Member: 1159663
Sonork: bydolek
loader iis opened but ,there is nothing to select to install.t
Old 06-10-2012, 23:17   #498 (permalink)
Member: 1460372
pls I got BB 9800 that the MEP CODE left 0
Old 06-16-2012, 10:09   #499 (permalink)
Member: 278001
thank u so much..........
Old 06-16-2012, 10:11   #500 (permalink)
Member: 278001
thanks a lot ramjan vhai............
Old 06-16-2012, 11:36   #501 (permalink)
Member: 1765167
Sonork: famewave
Hav prolem with Blackberry 8300..... When i put the battery the red blinks normally but then it displays "JUM Error 102 RESET" With a white sdcreen. Plz help!
Old 06-18-2012, 08:48   #502 (permalink)
Member: 100241
please how to flash bold 5
thanks advance.
Old 06-19-2012, 09:49   #503 (permalink)
Member: 478331
dear friend i need 8520 bold softwear....thx in advnc
Old 07-02-2012, 10:10   #504 (permalink)
Member: 1774873
Sonork: NONE
hi i want to flash my blackberry curve its freezing on blackberry please help...
Old 07-02-2012, 16:06   #505 (permalink)
Member: 1775000
hey guys i just flashed my bb 8520 and all was good but after few hours its started restart again and again guys any help?
Old 07-02-2012, 16:38   #506 (permalink)
Member: 1775000
redd this post it might be helpful for you
BlackBerry Phones Update/Flash Easy Way;)
Old 07-08-2012, 15:48   #507 (permalink)
Member: 1457278
Sonork: mohammedamjad.com
is there possible to unlock blackberry in ufs or mxkey
The Following User Says Thank You to Mohammed Amjad For This Useful Post:
Old 07-08-2012, 18:21   #508 (permalink)
Member: 1781998
Is it hard to unlock a blackberry storm
Old 07-08-2012, 18:22   #509 (permalink)
Member: 1781998
Is a blackberry better than a android
Old 07-08-2012, 18:22   #510 (permalink)
Member: 1781998
What problems do most blackberrys have
How to flash blackberry phone luyanda BlackBerry (RIM) 16 07-22-2012 09:18
How to flash Dead Blackberry phones? Parbon BlackBerry (RIM) 9 06-07-2011 13:02
Solution for DEAD PHONE after flashing with mobileEx 3.3 (rev1.7_fixed)!! curvenger MXKEY Nokia Flasher and Unlocker (by Alim Hape) 16 01-09-2011 16:00
New Blackberry phones supporting by Easy unlocker Miftahudin Easy-Unlocker 1 12-09-2008 17:56
Page generated in 0.33892 seconds with 12 queries
