Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > BlackBerry (RIM)
BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs.
Old 02-15-2015, 09:55   #1 (permalink)
Member: 1956900
Exclamation BlackBerry Q10 Empty Board Red Light Blinking 10111111
Please help!!!!
Having a BlackBerry Q10 fully blank
No IMEI, ESN, PIN
I had flashed autoloder 10.2.1
After flashing it has an error came, red light blinking 10111111, so many times flashed another autoloders but nothing changes on it
Q10 wants turn-on but which error courses it I don't know
If any buddy having solution please co-oprate with me
Thanks....
Old 02-27-2015, 21:05   #2 (permalink)
Member: 477232
Have you solved?
My Z30 have same problem....can you help me?
I'm writing from Italy
Old 02-27-2015, 22:17   #3 (permalink)
Member: 1956900
Almost no way for this situation,
Try with another autoloder,
Old 03-02-2015, 09:15   #4 (permalink)
Member: 619957
Thanks Meter: 50
try with old versions if solved then update it via ota
Old 03-04-2015, 07:24   #5 (permalink)
Member: 477232
Hi gulab can you explain what is "ota"?
Old 03-04-2015, 12:39   #6 (permalink)
Member: 619957
Thanks Meter: 50
ota means over to air bro its simple update via wi-fi
Old 03-08-2015, 20:08   #7 (permalink)
Member: 1663119
Sonork: iffi3
Thanks Meter: 213
IMEI,ESN,PIN I don't think its repairable
The Following User Says Thank You to iffipower For This Useful Post:
Old 04-03-2015, 16:45   #8 (permalink)
Member: 1067261
Thanks Meter: 54
need to load empty files then correct signature after is possible to become normal..............but this method no free or public
Old 04-17-2016, 14:36   #9 (permalink)
Member: 2560559
I have the same problem, I have blackberry Q10 with red light flashing and do not load any OS using the auto-loader. I tried many auto loader but after writing my mobile displays blackberry 10 for 1-2 seconds and disappears and nothing works after that. I installed Chimera tool with three days trial. it detects my phone, displays phone info, using change software click its flashes 100% but later still same thing. the phone won't work simply.
I tried Nuke Phone but at 6% it disconnects from my computer and then I have to wait for another 3 hours to redo the process. I almost tried everything but do not know if there is any solution to restore my blackberry
any help will be greatly appreciated. tell me if I am doing something wrong...!!
Old 04-24-2016, 02:13   #10 (permalink)
Member: 2206324
Sonork: 100.1656598
replace ic flash, done.
Old 04-24-2016, 20:11   #11 (permalink)
Member: 513803
Blackberry Q10 empty board
Originally Posted by raghav9 View Post
Please help!!!!
No IMEI, ESN, PIN
Thanks....
Does anybody have solution for this?
Old 04-25-2016, 00:41   #12 (permalink)
Member: 513803
Will Ic change solve the problem?
Old 05-03-2016, 06:47   #13 (permalink)
Member: 2560559
what IC flashing thing is ??
can someone explain please....
Page generated in 0.20322 seconds with 8 queries
