BlackBerry software * hardware reset here BlackBerry software * hardware reset here BlackBerry 9700 Bold hard reset http://st2.gsmarena.com/vv/pics/blac...-Bold-9700.jpg Press: ALT + SHIFT + DEL or Format the device memory or a media card If you format the BlackBerry® device memory or a media card, all the files in the device memory or on the media card are deleted. Depending on your device model, you might not be able to format your device memory. 1. On the Home screen or in a folder, click the Options icon. 2. Click Memory. 3. Press the Menu key. 4. Click Format. 5. Complete the instructions on the screen. Warning: All data on your phone will be deleted. http://sig.graphicsfactory.com/Psychedelic/g.gifhttp://sig.graphicsfactory.com/Psychedelic/s.gifhttp://sig.graphicsfactory.com/Psychedelic/m.gifhttp://sig.graphicsfactory.com/Psychedelic/j.gifhttp://sig.graphicsfactory.com/Psychedelic/a.gifhttp://sig.graphicsfactory.com/Psychedelic/k.gifhttp://sig.graphicsfactory.com/Psychedelic/e.gifhttp://sig.graphicsfactory.com/Psychedelic/r.gif |
BlackBerry 9670 Bold http://st2.gsmarena.com/vv/pics/blac...yle-9670-1.jpg Reset the device Performing a Hard Reset on a BlackBerry Style 9670 Series A full reset is sometimes referred to as a hard reset. Perform a full reset when you want to clear all settings, programs and data from RAM. Caution if you perform a full reset, your BlackBerry Style 9670 returns to its default settings and looses all information that is not recorded in ROM. Before you delete your BlackBerry® device data or media card files, consider backing up these items so that you have a copy on your computer. CAUTION: If you have turned on encryption, the process for deleting all device data can take up to an hour to complete. You cannot stop the process after you start it. If you reset your device, the process restarts after the device restarts. To perform a hard reset: 1. On the Home screen or in a folder, click the Options icon. 2. Click Security *gt; Security Wipe. * To delete data from the messages application, contacts application, and other applications, select the Emails, Contacts, Etc check box. * To delete all third-party applications that you have added, select the User Installed Applications check box. * To delete all files from your media card, select the Media Card check box. 1. Type blackberry. 2. Click Wipe. |
BlackBerry 9300 http://st2.gsmarena.com/vv/pics/blac...Curve-3G-2.jpg Reset the device A full reset is sometimes referred to as a hard reset. Perform a full reset when you want to clear all settings, programs and data from RAM. Caution if you perform a full reset, your BlackBerry Curve 9300 returns to its default settings and looses all information that is not recorded in ROM. Before you delete your BlackBerry® device data or media card files, consider backing up these items so that you have a copy on your computer. CAUTION: If you have turned on encryption, the process for deleting all device data can take up to an hour to complete. You cannot stop the process after you start it. If you reset your device, the process restarts after the device restarts. To perform a hard reset: On the Home screen or in a folder, click the Options icon. Click Security *gt; Security Wipe. To delete data from the messages application, contacts application, and other applications, select the Emails, Contacts, Etc check box. To delete all third-party applications that you have added, select the User Installed Applications check box. To delete all files from your media card, select the Media Card check box. Type blackberry. Click Wipe. |
BlackBerry 9100 hard reset http://www.mobilegazette.com/handset...pearl-3g-1.jpg Reset the Blackberry 9100 pearl device A full reset is sometimes referred to as a hard reset. Perform a full reset when you want to clear all settings, programs and data from RAM. Caution if you perform a full reset, your BlackBerry Curve 9300 returns to its default settings and looses all information that is not recorded in ROM. Before you delete your BlackBerry® device data or media card files, consider backing up these items so that you have a copy on your computer. CAUTION: If you have turned on encryption, the process for deleting all device data can take up to an hour to complete. You cannot stop the process after you start it. If you reset your device, the process restarts after the device restarts. To perform a hard reset: On the Home screen or in a folder, click the Options icon. Click Security *gt; Security Wipe. To delete data from the messages application, contacts application, and other applications, select the Emails, Contacts, Etc check box. To delete all third-party applications that you have added, select the User Installed Applications check box. To delete all files from your media card, select the Media Card check box. Type blackberry. Click Wipe. |
BlackBerry 9600 Tour hard reset http://www.celutec.cl/media/catalog/...rry_9600_1.jpg Reset the device A full reset is sometimes referred to as a hard reset. Perform a full reset when you want to clear all settings, programs and data from RAM. Caution if you perform a full reset, your BlackBerry 9600 or 9630 Tour returns to its default settings and looses all information that is not recorded in ROM. Before you delete your BlackBerry® device data or media card files, consider backing up these items so that you have a copy on your computer. CAUTION: If you have turned on encryption, the process for deleting all device data can take up to an hour to complete. You cannot stop the process after you start it. If you reset your device, the process restarts after the device restarts. To perform a hard reset: On the Home screen or in a folder, click the Options icon. Click Security *gt; Security Wipe. To delete data from the messages application, contacts application, and other applications, select the Emails, Contacts, Etc check box. To delete all third-party applications that you have added, select the User Installed Applications check box. To delete all files from your media card, select the Media Card check box. |
BlackBerry 9500 Storm hard reset http://st2.gsmarena.com/vv/pics/blac...0-storm2-1.jpg Reset the Blackberry 9500 or 9530 device A full reset is sometimes referred to as a hard reset. Perform a full reset when you want to clear all settings, programs and data from RAM. Caution if you perform a full reset, your BlackBerry Storm 9500 or 9530 returns to its default settings and looses all information that is not recorded in ROM. Before you delete your BlackBerry® device data or media card files, consider backing up these items so that you have a copy on your computer. CAUTION: If you have turned on encryption, the process for deleting all device data can take up to an hour to complete. You cannot stop the process after you start it. If you reset your device, the process restarts after the device restarts. To perform a hard reset: 1. On the Home screen or in a folder, click the Options icon. 2. Click Security *gt; Security Wipe. * To delete data from the messages application, contacts application, and other applications, select the Emails, Contacts, Etc check box. * To delete all third-party applications that you have added, select the User Installed Applications check box. * To delete all files from your media card, select the Media Card check box. 1. Type blackberry. 2. Click Wipe. |
BlackBerry 9630 Bold http://image.tradevv.com/2010/03/27/...-8900-8330.jpg Reset the device A full reset is sometimes referred to as a hard reset. Perform a full reset when you want to clear all settings, programs and data from RAM. Caution if you perform a full reset, your BlackBerry Bold 9700 Bold2 or 9780 returns to its default settings and looses all information that is not recorded in ROM. Before you delete your BlackBerry® device data or media card files, consider backing up these items so that you have a copy on your computer. CAUTION: If you have turned on encryption, the process for deleting all device data can take up to an hour to complete. You cannot stop the process after you start it. If you reset your device, the process restarts after the device restarts. To perform a hard reset: On the Home screen or in a folder, click the Options icon. Click Security *gt; Security Wipe. To delete data from the messages application, contacts application, and other applications, select the Emails, Contacts, Etc check box. To delete all third-party applications that you have added, select the User Installed Applications check box. To delete all files from your media card, select the Media Card check box. Type blackberry. Click Wipe. |
BlackBerry 8500 hard reset http://st2.gsmarena.com/vv/pics/blac...curve-8520.jpg Reset the device A full reset is sometimes referred to as a hard reset. Perform a full reset when you want to clear all settings, programs and data from RAM. Caution if you perform a full reset, your BlackBerry Curve 8520 or 8530 returns to its default settings and looses all information that is not recorded in ROM. Before you delete your BlackBerry® device data or media card files, consider backing up these items so that you have a copy on your computer. CAUTION: If you have turned on encryption, the process for deleting all device data can take up to an hour to complete. You cannot stop the process after you start it. If you reset your device, the process restarts after the device restarts. To perform a hard reset: On the Home screen or in a folder, click the Options icon. Click Security *gt; Security Wipe. To delete data from the messages application, contacts application, and other applications, select the Emails, Contacts, Etc check box. To delete all third-party applications that you have added, select the User Installed Applications check box. To delete all files from your media card, select the Media Card check box. Type blackberry. Click Wipe. |
BlackBerry 8900 http://st2.gsmarena.com/vv/pics/blac...bb-8900-01.jpg Reset the device A full reset is sometimes referred to as a hard reset. Perform a full reset when you want to clear all settings, programs and data from RAM. Caution if you perform a full reset, your BlackBerry Curve 8900 or 8910 returns to its default settings and looses all information that is not recorded in ROM. Before you delete your BlackBerry® device data or media card files, consider backing up these items so that you have a copy on your computer. CAUTION: If you have turned on encryption, the process for deleting all device data can take up to an hour to complete. You cannot stop the process after you start it. If you reset your device, the process restarts after the device restarts. To perform a hard reset: On the Home screen or in a folder, click the Options icon. Click Security *gt; Security Wipe. To delete data from the messages application, contacts application, and other applications, select the Emails, Contacts, Etc check box. To delete all third-party applications that you have added, select the User Installed Applications check box. To delete all files from your media card, select the Media Card check box. Type blackberry. Click Wipe |
hello... i have BB 8900, its charge battery but after some time its start blink red light... plz tell me is it hardware or software.....? |
my blackberry 8520 only show app error in desplay how to hard reset |
regards |
Blackberry 8520 unloking 100% solve |
blackberry 9860 hard reset pls hlp |
