BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
04-24-2013, 06:58 | #1 (permalink) |
No Life Poster Join Date: Apr 2007 Location: CLOUD Age: 40
Member: 486357 Status: Offline Sonork: 100.1602846 Thanks Meter: 1,220 | bb 9800 You will need to reload the FS on your device NUke wipe Mfi flash but problem same restart some time fully work for few min then again restart C:\Documents and Settings\MISS MY LOVE>C:\cfp.exe load "C:\ALRF 9800.sfi" RIM Wireless Device Command-Line Programmer Version 3.9.0.249 Copyright 2012 Research In Motion Limited Connecting to Bootrom: Connected [ Writing 0x00000093 ] [############## 100 ##############] *** The FS region has been moved and therefore is corrupted. The FS region will be wiped. *** *** You will need to reload the FS on your device. *** [ Erasing 0x1F13FFFF ] [############## 100 ##############] Done. how to solved this problem |
04-24-2013, 07:18 | #2 (permalink) |
Registered User Join Date: May 2008 Location: ...::IsLam::... Age: 39
Member: 767472 Status: Offline Sonork: 100.1609877 Thanks Meter: 599 | check ur fone battery and battery teminals Bsi line voltage |
The Following 2 Users Say Thank You to .....::::GsmAdeel:::::..... For This Useful Post: |
04-26-2013, 07:18 | #6 (permalink) |
Member: 486357 Status: Offline Sonork: 100.1602846 Thanks Meter: 1,220 | Connecting to Bootrom: Connected Uploading RAM Image...OK Bootrom Version: 5.10.0.13 Hardware ID: 0x05001807 RIM BlackBerry Device HW ID Override: None Metrics Version: 6.16 Build Date: Jul 22 2010 Build Time: 10:01:31 Build User: ec_agent Security: Enabled Supported Options: 0x00000009 Drivers: 0x00000024 Processor: 0x00000001 LDR Blocks: 0x5C026F04 Bootrom Size: 0x00020000 External MCT/HWV: Enabled Boot Mode: N/A Boot OS Count: N/A HWV: Board Revision 0001 - 0x21 CPU Version 0002 - 0xD8 SW Compatibility 0003 - 0x02 POP Revision 0004 - 0x05 Power Mgt Hardware 0007 - 0x2F POP Security 000B - 0x01 GPS 000C - 0x06 ROM MASK Version 000D - 0x09 Hearing Aid Compat 0037 - 0x01 WCDMA Band supported 003B - 0x00 BSIS support 0041 - 0x01 Mem Config Table (ver 1.20): Flash Chip: blocks 0-2000, Chip 0, Sub 0 Bootrom: blocks 0-0 OS Dynamic: blocks 2-???? FS Dynamic: blocks ????-1988 OS NV: blocks 1989-2000, total 12 RAM Chip: 0xB0000000-BFFFFFFF, Bank Size 67108864 RAM Chip: 0xC0000000-CFFFFFFF, Bank Size 67108864 CRC: 0x9A00B6E7 Mem Config Table (ver 1.20) (actual): Flash Chip: blocks 0-2000, Chip 0, Sub 0 Bootrom: blocks 0-0 OS Fixed: blocks 2-75 UMP Fixed: blocks 76-122, total = 47 FS Fixed: blocks 123-1988, total = 1866 OS NV: blocks 1989-2000, total 12 RAM Chip: 0xB0000000-BFFFFFFF, Bank Size 67108864 RAM Chip: 0xC0000000-CFFFFFFF, Bank Size 67108864 CRC: 0x88B9DE8A Flash: Number of chips: 1 Flash ID: NAND blocks 0-2000 Device ID: 80 Vendor ID: 236 Version ID: 49 Total Size: 500.3 MB Memory Map: NAND Blocks: 2001 * 256 Kb RAM Base: 0xB8000000 IRAM Base: 0x5C000000 OS Range: 2 - 75 File System: Memory Map: 123 - 1988 Sectors: 1866 Branding: VendorID: 603 OS Version: 6.4.0.105 Hardware ID: 0x05001807 RIM BlackBerry Device Metrics Version: 3.18 FS Code Version: 10.0.0.0 FAT Code Version: 2.33 Package Version: "6.4.0.105" Build Date: Sep 18 2010 Build Time: 01:35:23 Build User: ec_agent SV Number: 4 OS Address: 0xB8000000-0xB927212B App Start: 0xB88D37DC Companion Binary: 0.0.0.0 RAM usage: 0xBE5FFFFC-0xBF4AFFFC IRAM End: 0xD0F90BF0 DSP ROM2 Address: *not present* OS Extended Addr: 0xB8CE0A18 LDR Blocks: 0xB8DC8280 API Checksum: 0x00000000 JumpTable (<3): 0xB8000388 JumpTable (>2): 0xB8002B6C Radio Code: Janus radio code linked OS API Version: 141.0 STP Protocol Ver: 5.222.4 (release OS) HWV: Board Revision 0001 - [0x0C - 0xFF], 0x01 POP Revision 0004 - [0x00 - 0xFF], 0x01 CPU Version 0002 - [0xD7 - 0xFF], 0x01 ROM MASK Version 000D - [0x09 - 0x09], 0x01 SW Compatibility 0003 - [0x00 - 0x02], 0x01 Power Mgt Hardware 0007 - [0x2F - 0xFF], 0x01 POP Security 000B - [0x00 - 0xFF], 0x01 WTE supported 003C - [0x01 - 0xFF], 0x00 WCDMA Band supported 003B - [0x00 - 0xFF], 0x01 Version Table: OS API Version: 141.0 STP protocol version: 5.222.4 BlockFS API Version: 10.0.0.0 USB driver version: 02.11 Bugdisp RTAS key: 1.0 STP RTAS key: 1.0 NVSIG RTAS key: 1.0 FAT FS Version: 2.33 Block map version: 2.17 NDK ABI version: 0.1 WLAN radio version: 4.2.0.38 Kernel Version: 2.0.0.214 Hardware ID: 0x05001807 RIM BlackBerry Device Metrics Version: 1.1 Build Date: Sep 13 2010 Build Time: 22:56:49 Build User: SCM App: Version: 6.0.0.246 (0x060000F6) Metrics Version: 1.7 Build Date: Sep 18 2010 Build Time: 11:01:35 Build User: RIM Memory Map: 0xB88D37DC-0xB8CE0A17 App c_main: 0xB8BD8A68 API Checksum: 0x00000000 JumpTable (<3): 0x00000000 JumpTable (>2): 0x00000000 AppFSVersion: 3.0.0.0 AppFSSize: 0x3200000 OS API Version: 141.0 RAM Map: 0xBCD00000-0xBE600000 IRAM Map: Unused App Type: JVM UMP: Name: OlympiaWebKit.elf Size: 3023552 bytes, blocks 76-87, offset 0 Name: OlympiaWebKitLDLL.ldll Size: 9077436 bytes, blocks 87-122, offset 140580 Task Status: Completed plz check restart problem s/w or h/w |
