1 Attachment(s) Hi friends tested Solution Problem BlackBerry 10 smartphone does not load, immediately after powering on a logo is displayed on the screen indicating that the device should be connected to a computer with a USB cable. Resolution To recover the BlackBerry 10 smartphone complete the following steps. NOTE - this procedure is only available on a Windows PC.
Again http://forum.gsmhosting.com/vbb/atta...1&d=1362671641 I ts Simple problem Follow the steps below
that's what i facing after trying to install updates: An error has occurred while downloading software for your device. Please verify your Internet connection or try again later, if the problem persists. note that my phone is working after i used autoloader but the issue that most the icons has gone. |
if you have any USB error while updating Contact me @ yahoo .... |
Does this solution work on windows 8? Getting error..... |
i got one white phone in recovery condition i tried Autoload-DevAlpha-10.0.10.263 it stars but closed in few seconds i also tried the above link but not working please help me |
hellp me A fatal error has occurred while updating your device's software. Please try again. |
Contact me in yahoo [email protected] |
you can simply connect phone without battery, insert battery when update is downloading. |
Theres no need to go to the web site to check for updates. Execute the loader as follows: "C:\Program Files\Common Files\Research In Motion\AppLoader\Loader.exe" /websl /invoker launchpad /language 1033 or create a shortcut with the above line in the Target field. |
I have tried many possible combinations to flash this phone.. Still its dead.. |
I had the same problem as my blackberry z10 was showing the connect to computer logo. I didn't check the battery status before I initiated the security wipe. All attempts to do the IE check for updates failed. @crackp0d gave me this link Updating the BlackBerry 10 Dev Alpha Device Software - Download for Windows - BlackBerry Developer The phone is back up now. All I have left is to restore the missing icons. I will keep you posted. |
command : cfp -u nuke -a (enter) cfp wipe (enter) Reload OS with BB Link |
its Work on window 8 me recover today z10 using same method thanks for nice info Br ask4moon :) |
how long thats process ocur,...update the z 10.... |
