Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2009 Location: banglore
Member: 1141761 Status: Offline Sonork: 100.1618159 Thanks: 27
| video link :::blackberry blinking red light solution by nasirvideo .rar check here for complete post ::http://forum.gsmhosting.com/vbb/f489...rking-1491453/ thanks regards nasir |
| The Following 7 Users Say Thank You to R.Nasir.Ali For This Useful Post: |
| | #2 (permalink) |
| blinking red light solution for all blackberry new and tried on 100s off bb modules success on all 1. download blackberry master control program and install it 2. download CFP_3.9.0.175.exe keep on desktop 3. open master control program and click on setting wheel on left hand side and in enable protected control type BrickBerry same as it is here 4. right click on alien face cfp button at left hand side. 5. below in cfp option (rim command-line program (cfp) executable ) select the cfp which you copied on desktop. 6. connect your bb without battery on top command-line interface (CLI) select wipe tick mark the empty box next to execute and press execute it will take 10 to 12 minutes after it finish disconnect your bb install a battery and wait for few minutes let the phone do its job. let the bb master control be open.......... now the trick is to load os 1. In bb master control on right hand side below right click on apploader it will loader/nojvm connect your phone follow the instruction thats it you have done the job.. please write me if you have any doubt or error thanks nasir if gives you error again go to step 6 select nuke and then wipe after this if says error dont cancel the procedure just disconnect the phone remove the battery re insert and wait untill the phone finish then connect the phone and press retry |
| | #7 (permalink) |
| Banned ![]() ![]() ![]() ![]() Join Date: Mar 2012 Location: BANGLADESH
Member: 1728755 Status: Offline Sonork: 100.1613242 Thanks: 249
| download link::BLACKBERRY_red_blinking_hangsolution by nasir.rar instaructions images:step 1. mcp a1.jpg step 2. cfp setting.bmp step 3. mcp device pin.bmp step 4. cfp commands 2.bmp step 4. os managenent mcp.bmp new models have problems of efs, ramimage, this is the problem and is solved with this software and the correct file's here the info------------------------------------ program info 1 info2 info3 info4 info5 info6 info7 ------------------------------------------------- b.r. Gsmjaker |
| The Following 4 Users Say Thank You to Shopno jaker For This Useful Post: |
| | #9 (permalink) | |
| Junior Member ![]() ![]() Join Date: Nov 2004 Age: 28
Member: 91994 Status: Offline Thanks: 5
| Quote:
I wonder if you really know the exact meaning of 100% when other BB red blink can be done by hardware and still you're claiming that your solution is 100% | |
| | #10 (permalink) | |
| Quote:
http://forum.gsmhosting.com/vbb/f489...rking-1491453/ MANY PLACES I HAVE MENTIONED CLEARLY THAT THIS SOLUTION IS FOR SOFTWARE PROBLEMS ONLY NOT HARDWARE (IF YOUR IS DEVICE IS DETECTED BY PC AND IF IT HAS A SOFTWARE COMPLAINT THEN YOU TRY THIS THANK U NASIR | |
| | #11 (permalink) |
| blackberry solution for blinking red light 100% working blinking red light solution for all blackberry new and tried on 100s off bb modules success on all 1. download blackberry master control program and install it 2. download CFP_3.9.0.175.exe keep on desktop 3. open master control program and click on setting wheel on left hand side and in enable protected control type BrickBerry same as it is here 4. right click on alien face cfp button at left hand side. 5. below in cfp option (rim command-line program (cfp) executable ) select the cfp which you copied on desktop. 6. connect your bb without battery on top command-line interface (CLI) select wipe tick mark the empty box next to execute and press execute it will take 10 to 12 minutes after it finish disconnect your bb install a battery and wait for few minutes let the phone do its job. let the bb master control be open.......... now the trick is to load os 1. In bb master control on right hand side below right click on apploader it will loader/nojvm connect your phone follow the instruction thats it you have done the job.. please write me if you have any doubt or error thanks nasir if gives you error again go to step 6 select nuke and then wipe after this if says error dont cancel the procedure just disconnect the phone remove the battery re insert and wait untill the phone finish then connect the phone and press retry I missed the part where you mentioned that it is only for software problem. Aside from the fact that the title is 100% misleading since it don't repair all red blink BB 100%. How about making it 50%? or if you're feeling lucky make it 80%.. lol |
| | #13 (permalink) | |
| Quote:
i wrote read my post. Link added there this is just video tutorial post..... Read the post and count how many TIME i wrote dont waste your and my time on argument nasir | |
| | #14 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Sep 2007 Location: nigeria
Member: 581848 Status: Offline Thanks: 291
| bros i ve downloaded all that u ve provided for this redblinking , i have 4 pics of 9900 all are red blinks and are detected by my pc but the problem is that after erasing it only stock on jvm and cant go more than that i ve downloaded ur video and followed it same but still cant go beyond jvm i downloaded the mml u posted yesterday but i dnt know how to use it plz can you help me in tutorial of how to use mml to solve the blinking.............thanks |
| | #15 (permalink) | |
| Quote:
Read the post above me and it will become 99% ![]() O.T.: Trying to make someone understand the importance of accuracy is never a waste of time.. ![]() Thanks.. | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Solution for GSM phones!?!?!?!? | todosije | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 12-16-2010 04:52 |
| Pic Solution | jan | Nokia Hardware & Hardware-Repair Area | 8 | 10-11-2010 10:56 |
| NEW ERICSSON A1018 £60 SIEMANS C25 £60 + LOADS MORE | MILLENNIUM-INTERNATIONAL | Main Sales Section | 0 | 08-31-1999 18:54 |
| !!!!!!TO ALL NOKIA 51XX/61XX SP LOCKS 1,2,3,4 SOLUTION latest news!!!!! | spterminator | Main Sales Section | 2 | 08-13-1999 05:55 |
| Anybody know solution | Robi | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 0 | 07-08-1999 09:14 |
