Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > BlackBerry (RIM)
BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs.
Old 03-26-2013, 04:34   #1 (permalink)
Member: 1881967
Sonork: 100.1626758
bold 9900 pin and imei change
Is there a way as yet to change the pin and imei of the bold 9900 ?
Old 03-26-2013, 12:50   #2 (permalink)
Member: 1715073
Thanks Meter: 24
yes there is a tool called LGE tool you can use this tool for only 20 credits (U$10)
Old 03-26-2013, 13:05   #3 (permalink)
Member: 1338781
Thanks Meter: 46
Supported models:
In our first balckberry release we made support for these phones:
9620, 9810, 9850, 9860, 9900, 9930, 9981.
All other models currently not supported. WE are working for adding more phone, kindly wait for further announcements.
Function description:
Unlock button: Allows you to make direct unlocking without code reading and code imput, irrespective of the MEP type in phone. Also this button reset the MEP code entry attempts (0 left).
Read code button: Allows you to read codes from your phone.
Repair imei button: It`s purpose to change or restore original IMEI of your phone
Remove operator logo button: Use it for full phone debranding - remove operator logo, reset vendor ID to to default one (-1) and return your cellphone to original factory settings.
Price:
Price 20 credits per phone for any number of operations (mep0 fix, unlock, IMEI repair, debranding). In order to use this feature your card must be registered and activated.
Cable:
To work with blackberry phones you should use Standart USB cable and modified SD card with power supply (+ 3.0 V) identical to set which you use for HTC phones.
What is MicroSD cable set:
You need
1) standart USB cable
2) microSD card (8MB - 4GB, don't use SDHC) with two thin wires (pin4=+3V, pin6=GND)
3) External power supply (+3V or +3.7V, for example 2xAAA battery).
4) Any MicroSD USB card reader:
How to work with this set with BLACKBERRY phones:
Firstly you put card in external card reader WITHOUT EXTERNAL POWER and make phone image with LGtool and simple USB cable.
after this you INSERT modified card to phone, CONNECT EXTERNAL POWER, connect USB cable to phone without battery and follow on-screen instruction.
How to work with this set with HTC phones
here
We recommend you to use quality SD cards like Samsung, Kingston etc. not less than 2 Gb size.
Usage:
here is example of program log when you repair IMEI on BB 9900
Connecting with 9900 Searching microSD disk...
MicroSD disk found:
Volume: F:\
Device: \\.\PhysicalDrive1
Label:
Writing image to microSD disk...
Writing image to microSD disk: OK
Waiting for User's Actions...
Searching Phone...
Getting Phone Info...
Serial Number: 99183bc0
BlackBerry RTAS Server Authorization...
Connecting to server...
Sending data to server...
Receiving data from server...
Sending RTAS Certificate to phone...
RTAS Authorization: OK
Connection With Phone...
Searching Phone...
Phone Found...
Connected
Repairing IMEI
Repairing IMEI... Please Wait...
Repairing IMEI: OK
IMEI: 351530-xx-xxxxxx-2
IMEI successfully repair
REFERENCE- http://support.lgtool.net/showthread...debranding-FAQ
Old 03-26-2013, 14:48   #4 (permalink)
Mr_F10ch3's Avatar
Member: 469532
Thanks Meter: 764
Dunot change pin or u gonna get no booting blackberry, if u all ready change pin restore to original pin to get bb booting ok again
Old 03-26-2013, 15:20   #5 (permalink)
Member: 1715073
Thanks Meter: 24
To make it work you have to change the complete info in the phone with IME+PIN+BSN that match to get a good boot
Old 03-26-2013, 15:27   #6 (permalink)
Mr_F10ch3's Avatar
Member: 469532
Thanks Meter: 764
Not work, tested using bsn+imei+pin from other good fone, all ready tested many times PIN can't be change at moment
Old 04-10-2013, 04:33   #7 (permalink)
Member: 437931
Sonork: pervaiz1001608612
Thanks Meter: 7
bb9900 i am change imei+bns+pin phone not booting in blackberry so pls change exe or add pin repair
Old 06-02-2013, 14:52   #8 (permalink)
Member: 1952137
pls has anyone solution to this?
I have same situation here, so pls help.
Old 10-02-2013, 14:02   #9 (permalink)
Crazy Poster
Member: 842648
imei tool indonesian
*RB-Tool version 1.0 ( release ) Supported by Delta Soft Development™.
*RB-Tool are under licensed from Delta Soft Development™.
*RB-Tool are just for repairing purpose only.
*IMEI changing are absolutely ilegal ( dedicated for repairing purpose only !!! ).
Old 10-02-2013, 14:32   #10 (permalink)
Member: 7103
Thanks Meter: 46
RB Tools v1.0 (Release)
Soon
Professional Blackberry Repair Special For: 9810 9850 9860 9930 9900
This Link
The Following 3 Users Say Thank You to rebi_cell For This Useful Post:
Old 10-02-2013, 15:12   #11 (permalink)
Member: 7103
Thanks Meter: 46
RB Tools v1.0 (Release) and private Tools/eMMC Disable
http://i531.photobucket.com/albums/d...93498947_n.jpg
The Following 2 Users Say Thank You to rebi_cell For This Useful Post:
Old 10-02-2013, 15:40   #12 (permalink)
Marscel_Jr's Avatar
Member: 1121495
Thanks Meter: 28
nice good....
(nunggu kapan louncing)
The Following 2 Users Say Thank You to Marscel_Jr For This Useful Post:
Old 10-02-2013, 16:06   #13 (permalink)
Member: 1876081
Thanks Meter: 5
Soon
Fitur RB TOOLS V.1.0 :
- Read flash chip type for engineering purpose"
- Flashing By blackberry Firmware installer
- Repair EFS Corrupt - Repair Red Blink All OS
- Repair Loading Stuck 10% - 100% (non Disable)
- Fixing Signal After Erase Modem EFS.
- Repair suspend all os 7.0 & os 7.1(*NV corrupted)
- Manual Erasing Support
- Write or Repair IMEI 00000 no server needed (0FFLINE)
# credit system offline but online#
This is the tool of Indonesia, Indonesian work forward,
suxes selalu pak Ayo
The Following 3 Users Say Thank You to sherlyn For This Useful Post:
Old 10-02-2013, 16:14   #14 (permalink)
irfan_gsm's Avatar
Member: 709520
Thanks Meter: 263
very good . we all waiting for public release . wish you all the best
The Following User Says Thank You to irfan_gsm For This Useful Post:
Old 10-03-2013, 23:30   #15 (permalink)
chubbie's Avatar
Member: 281801
Sonork: 100.1608672
Thanks Meter: 150
When will this be release to the public
Page generated in 0.39653 seconds with 7 queries
