BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
01-01-2012, 02:22 | #31 (permalink) | |
No Life Poster Join Date: Mar 2005 Location: wales uk
Member: 125632 Status: Offline Thanks Meter: 233 | Quote: password please it no use posting files if your not going give the password. | |
The Following User Says Thank You to bcatlock1 For This Useful Post: |
01-01-2012, 16:25 | #33 (permalink) |
Freak Poster Join Date: May 2010
Member: 1297888 Status: Offline Thanks Meter: 78 | I was just searching at the link and find a link cfp from 4shared I am posting it here in case anyone got the password and share it here, because I also need to the file. if anyone have its code, please share here.... thanks |
The Following 2 Users Say Thank You to MXKEY_OK For This Useful Post: |
01-02-2012, 16:12 | #35 (permalink) |
No Life Poster Join Date: Jan 2011 Location: Honduras
Member: 1488173 Status: Offline Thanks Meter: 194 | I have the cfp patched to load unsigned mfi, but is too old, we need to patch the new version, Somebody know how to patch cfp to allow load unsigned files ?? |
01-30-2012, 12:58 | #39 (permalink) | |
No Life Poster Join Date: Sep 2004 Location: NeverL@Nd
Member: 82106 Status: Offline Thanks Meter: 1,208 | Quote:
do you have one of those files to test with the cfp? yes some of the MFI comes without crypto signed from the rim, but i mean do you have one which you made by yourself? | |
01-30-2012, 20:49 | #41 (permalink) | |
Member: 1297888 Status: Offline Thanks Meter: 78 | Quote:
Other than that just modification | |
01-31-2012, 04:56 | #44 (permalink) |
Insane Poster Join Date: Jan 2012
Member: 1712596 Status: Offline Thanks Meter: 25 | ALD Wireless Device Command-Line Programmer Version 4.0.0.00 Copyright 2010 Research In Motion Limited ************** Info Dump ******************** *** Version 3.9.0.165 *** Build date: Apr 12 2011 (18:31:52) *** Compiler: vc9 *** CMDLine: /u /v2 info ************ Info Dump END ****************** --> Using USB timeout values. Connecting to Bootrom: Connected Device Info: PIN: 215b2490 Bootrom Version: 5.6.0.20 Hardware ID: 0x8C000F03 RIM BlackBerry Device HW ID Override: None Supported Bands: 0x000F Metrics Version: 6.9 Build Date: May 13 2009 Build Time: 13:25:04 Build User: rdagg Security: Enabled Supported Options: 0x00000003 Drivers: 0x00000004 Processor: 0x00000001 LDR Blocks: 0x87FEB474 Bootrom Size: 0x00020000 External MCT/HWV: Enabled Boot Mode: N/A Boot OS Count: N/A HWV: Board Revision 0001 - 0x05 CPU Version 0002 - 0x32 SW Compatibility 0003 - 0x01 POP Revision 0004 - 0x05 Power Mgt Hardware 0007 - 0x27 POP Security 000B - 0x01 Mem Config Table (ver 1.16): Flash Chip: blocks 0-2000, Chip 0, Sub 0 Bootrom: blocks 0-0 OS Dynamic: blocks 2-???? FS Dynamic: blocks ????-1983 OS NV: blocks 1984-2000, total 17 CRC: 0xBE91091F Flash: Number of chips: 1 Flash ID: NAND blocks 0-2020 Device ID: 68 Vendor ID: 236 Version ID: 0 Total Size: 252.6 MB Memory Map: NAND Blocks: 2021 * 128 Kb RAM Base: 0x80000000 IRAM Base: no IRAM! OS Range: 2 - 85 File System: Memory Map: 86 - 1983 Sectors: 1898 Branding: VendorID: 215 OS Version: 4.2.0.9 Hardware ID: 0x8C000F03 RIM BlackBerry Device Supported Bands: 0x0000FFFF Metrics Version: 3.16 FS Code Version: 10.0.0.0 FAT Code Version: 2.18 Package Version: "" Build Date: Enr 07 2012 Build Time: 01:43:14 Build User: ALDO SV Number: 1 OS Address: 0x80000000-0x80A6249F App Start: * No Application Linked * Companion Binary: 0.0.0.0 RAM usage: 0x874FFFFC-0x87FFFFFC IRAM End: 0x4009E378 DSP ROM2 Address: *not present* OS Extended Addr: 0x809450F8 LDR Blocks: 0x80A2C960 API Checksum: 0x00000000 JumpTable (<3): 0x80000310 JumpTable (>2): 0x80001F78 Radio Code: Orpheus radio code linked OS API Version: 109.40 STP Protocol Ver: 5.147.1 (factory OS) HWV: Board Revision 0001 - [0x01 - 0xFF], 0x01 POP Revision 0004 - [0x00 - 0xFF], 0x01 CPU Version 0002 - [0x00 - 0xFF], 0x01 SW Compatibility 0003 - [0x00 - 0x01], 0x01 Power Mgt Hardware 0007 - [0x24 - 0xFF], 0x01 Version Table: OS API Version: 109.40 STP protocol version: 5.147.1 BlockFS API Version: 10.0.0.0 USB driver version: 02.01 Bugdisp RTAS key: 1.0 STP RTAS key: 1.0 NVSIG RTAS key: 1.0 FAT FS Version: 2.18 Block map version: 2.6 WLAN radio version: 2.5.0.73 Kernel Version: 1.11.0.241 Hardware ID: 0x8C000F03 RIM BlackBerry Device Metrics Version: 1.1 Build Date: Enr 07 2012 Build Time: 00:59:28 Build User: ALDO Done. --> CFP_Imp::Abort() called --> USBDriver::Abort() called --> USBDriver::Abort() called |
How to use Nokia tool - with connection 6-7 pin or not?.. | 2M | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-20-2000 19:53 |
How can I use AT command control Nokia6110?Help me! | arnom | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 07-15-2000 07:35 |
Is it possible to use the Nokia 6150 with the IR Port of a Toshiba Laptop? | telefonman | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 02-13-2000 20:06 |
how can we use *.scr files to unlock | shadow77 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-27-1999 03:13 |
Startup Logo to be used as Operator Logo | Beachbum | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-09-1999 18:43 |
