Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > BlackBerry (RIM)
BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs.
Old 06-15-2010, 14:57   #1 (permalink)
Member: 1323289
Changing IMEI failed?
Hi all, I've spent 2 days searching for guides and tutorials of how to change the IMEI and PIN of my Bold 9000. I found it, it went all good and smooth, it actually was quite simple. Anyway, I've changed my IMEI with another one found on my old 7290, which was fully working and was able to register with BIS , on my bold I was able to call but the EDGE icon was lowercase, can you tell me why is that? Is it my fault? Should I try rewriting it using a generated code based on my old IMEI and PIN?
Old 06-15-2010, 15:41   #2 (permalink)
Ashwani Gaur's Avatar
Member: 2822
Why not post How you Changed IMEI - tutorial, as many here are not able to get success.
regards
Old 06-15-2010, 16:05   #3 (permalink)
Member: 965657
Start
Connect your BB and make a back-up of anything on it you would like to keep as we will be erasing its contents including the OS.
First, you will need these softwares:
Copy of OS you want on your device- You must have this.
Radiolab Tool
MFI Multiloader-Need all parts of multiloader.
Do a google search for the software. There are many torrents for the Multiloader.
To start:
1. Install the MFI Multiloader to your computer. You must install the complete program otherwise none of this will work. Do your research.
2. Connect your BB to your computer with usb cable. Do not start the desktop manager.
3. Open the MFI Multiloader, it will recognize your phone and will wipe all contents from the phone.
4. Look at the screen on your BB while the program is compiling, when the screen shows a large 1 in the upper left corner, close the multiloader. I repeat when you see a large 1 on your BB, close out the MFI Multiloader program.
5. Open the Radiolab Tool. It contains a program which looks similar to CDMA Workshop. Under the available views tab there is a tab marked ID. Highlight the ID tab.
6. Make sure your BB is still connected to your computer. Click the connect button located in the top left corner of the Radiolab Tool. On the lower screen it shoould say connected.
7. On the right screen you will see IMEI, BSN, BBPIN, and other lines. Click read on the IMEI line, it will read the IMEI from your phone. Replace the old IMEI with the new IMEI you want on your phone. Click write and it should be written to your phone.
8. On the BBPIN line click read. Replace the old BBPIN with your new Pin and click write.
9. After writing the pin click the disconnect button located next to the connect button on the radiolab tool.
10. Now all you have to do is load your OS back onto your BB. I used the loader /nojava method through the command prompt. You can try to load it with the apploader. It may or may not work, I kept to what worked for me.
Using this process I was able to successfully change the esn and pin on two 8330's. I was also able to change back to the original esn's and pin's.
One thing___You must have an esn and pin combination from RIM if you plan on ever registering with BIS/BES. Luckily I had a couple of damaged BB's I was able to use the esn/pin's off of to change out.
The Following 3 Users Say Thank You to d1ulove For This Useful Post:
Old 06-15-2010, 17:43   #4 (permalink)
Member: 1323289
That's the guide I followed
P.S.: any solution to my problem?
Old 06-16-2010, 18:45   #5 (permalink)
Member: 2822
there are two or more different versions of MFI Multiloader, which one you used?
Old 06-16-2010, 18:53   #6 (permalink)
fabicel's Avatar
Member: 808967
that models can change imei and 8520 8900
Old 06-16-2010, 21:56   #7 (permalink)
Crazy Poster
Member: 1015559
Sonork: IT-Specialist
Thanks bro ''d1ulove'' good sharing of knowledge, keep it up, i expecting from you in future, as i new and i want to know more about BB.
Thanks
Old 06-26-2010, 23:26   #8 (permalink)
Member: 146708
Sonork: 100.108221
8900..? did u test it..?
Old 06-28-2010, 19:55   #9 (permalink)
JAVAZ's Avatar
Member: 726032
Sonork: ....Ssstt....
BB 8520..!!!?? are you sure..??!!
Old 06-28-2010, 20:32   #10 (permalink)
Member: 1040392
I did it once, and it worked, but i had an issue trying to activate the phone with a new service provider. the imei is related to the pin, an the BIS does not accepted it.
Old 06-28-2010, 20:33   #11 (permalink)
Member: 1275794
Idont think about that. If you can change the ime and pin on 8900 and 8520, please let us know how you did it and the programs
Old 06-30-2010, 01:28   #12 (permalink)
MauricioBC's Avatar
Member: 701656
Sonork: 100.1605121
for 8520 8900 etc not free solution!
what prog changes imei on 6110 and how do i do it? Ravetrancer Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 07-31-2012 20:09
Nokia 51xx/61xx imei changer ver. 1.10?????? Ravetrancer Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 8 04-06-2012 16:22
6110 imei changer !!!!!! Ravetrancer Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 5 11-21-2011 00:44
ESN Change OGOMEZ Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 09-21-1999 23:56
Imei Arnis Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 09-15-1999 02:38
Page generated in 0.31620 seconds with 11 queries
