Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > BlackBerry (RIM)
BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs.
Old 12-06-2004, 13:04   #1 (permalink)
gsmfactory's Avatar
Member: 5752
Thanks Meter: 13
How to Enter Unlock Code in a BlackBerry 7230 ?
Dear Sir,
We receive some unlock code for Blackberry 7230 locked on SFR FRANCE & Vodafone but we don't have the instruction for "HOW TO ENTER CODE" in phone.....
Anybody have the solution ?
The Following User Says Thank You to gsmfactory For This Useful Post:
Old 12-07-2004, 01:00   #2 (permalink)
spear's Avatar
Member: 272
Thanks Meter: 75
www.bongowireless.com
Old 12-07-2004, 10:46   #3 (permalink)
gsmfactory's Avatar
Member: 5752
Thanks Meter: 13
This don't answer to my question..... just show bongowireless unlock this model but what I want to know is HOW TO enter the Code I allready receive to unlock this blackberry ?
Thanks in advance for the answer.
Old 12-09-2004, 22:32   #4 (permalink)
gsmfactory's Avatar
Member: 5752
Thanks Meter: 13
Still no tips for my problem ?
Old 03-18-2005, 17:11   #5 (permalink)
Member: 4398
Did you find the solution to this ?
Old 04-13-2005, 23:46   #6 (permalink)
Member: 33320
Thanks Meter: 6
Originally Posted by gsmfactory
Dear Sir,
Go to : Settings, SIM Card, and select
Hold the shift letter and type MEPD while holding shift, then while holding shift type MEPE then enter the unlock code.
Tested & work 100%.
B.R.
Dusko
[email protected]
The Following User Says Thank You to duskor For This Useful Post:
Old 05-28-2005, 22:35   #7 (permalink)
mrfixit's Avatar
Member: 60899
Thanks Meter: 792
shift mepd and mepe dont work for me but shift mep2 for 7100t works ok.
Old 05-21-2006, 11:54   #8 (permalink)
Member: 165303
Sonork: 100.1580123
Thanks Meter: 57
How to Enter Unlock Code in a BlackBerry 7100g
Old 05-21-2006, 11:59   #9 (permalink)
gsmfactory's Avatar
Member: 5752
Thanks Meter: 13
Thanks to www.unlock-blackberry.com for this but here is procedure directly from T-Mobile Operator :
Thank you for taking the time to contact T-Mobile. Below you will see the Instructions for unlocking your Blackberry device.
NOTE: If you receive an error message while performing the instructions below, stop. Please be aware that if an excessive amount of incorrect attempts are made, the phone will be permanently locked. Verify the IMEI by pressing *#06# and submit a new request.
Warning! The Wireless Mode MUST BE OFF before performing the given SIM Unlock instructions in order to avoid causing the device from becoming defective.
How to turn Wireless Mode Off:
1. Scroll to the Airplane Icon (Turn Wireless Off.)
2. Press Select.
3. Wireless Mode will turn off.
4. REMOVE the SIM card
5. Power On the Device (Put the Battery back in)
How to SIM Unlock the device:
1. Go to the "Tools" screen
2. Select "Settings"
2. Select the "SIM Card" option
3. Type MEPPD
4. It should then display a list "SIM, Network, Network Subset, etc..."
5. To select "Network" type MEPP Alt-2
6. It should then ask for the code
7. Enter the unlock code
Thank You,
Sim Unlock Department
T-Mobile USA, Inc.
The Following 2 Users Say Thank You to gsmfactory For This Useful Post:
Old 06-24-2009, 13:36   #10 (permalink)
Member: 779470
Sonork: Waseem mobile
Thanks Meter: 101
this is right
2. Press Select.
3. Type MEPD
5. To select "Network" type MEP Alt-2
The Following User Says Thank You to waseem pirmahal For This Useful Post:
Old 11-09-2009, 10:13   #11 (permalink)
Registered User
Member: 340703
Sonork: 100.1592496
Thanks Meter: 226
how to unlock blackberry 7230
Old 11-09-2009, 10:38   #12 (permalink)
DON THE KILLER's Avatar
Member: 619319
Sonork: 100.1590240
Thanks Meter: 76
# Select Options menu on BB.
# Now you select SIM CARD menu. To be able to see this you have to type this on the keypad on phone : (TEXT WILL NOT APPEAR ON THE SCREEN until you enter the unlock code)
# Type 'MEPD' for all models except 7100 in which case in case use 'MEPPD'.
# Usually u should see "active" NET lock. Now in order to disable this lock type 'MEP2' respectively 'MEPP2' if phone is 7100 and will appear a dialog asking for code. NOTE: You must use the "alt" or "shift" key to enable numbers so example would be: m-e-p-"alt key"-2 Now you should see the place to enter your net unlock code.(if not, you didn't type in mep2 or mepp2 properly.)
# Here you must enter the "NET Unlock Code"
Regards
Old 11-09-2009, 10:42   #13 (permalink)
Member: 619319
Sonork: 100.1590240
Thanks Meter: 76
Regards
Old 04-10-2010, 11:15   #14 (permalink)
way2unlock's Avatar
Member: 582682
Sonork: 100.1607124
Thanks Meter: 136
2. Press Select.
3. Type MEPD
thanks dear i have unlock vodafine blackberry 7320 by code in your stup thank brother
Old 09-21-2012, 20:44   #15 (permalink)
Member: 223818
Thanks Meter: 31
even its an old post but its still helps thank you for the help
How to enter unlock codes in samsung s3650, not accept codes when i enter,why? svchost NSPRO 22 05-07-2014 11:00
How to enter unlock code in blackberry 8900 Momo_Gsm BlackBerry (RIM) 4 10-23-2010 11:39
how to enter unlock code in modem after getting unlock code from MXKEY (Answered) NAVEED74 MXKEY FREE ADD-ONS: HTC Unlocker, HUAWEI and VODAFONE MODEMS Unlocker 1 03-06-2010 14:25
detail to enter unlock code in all blackberry tahir rafiq BlackBerry (RIM) 0 10-03-2009 00:54
Page generated in 0.23230 seconds with 9 queries
