05-11-2009, 13:22
#1 (permalink)
Member: 32529
Thanks Meter: 23 | to expert ... any one can help with BB 8700 hi
i need help from expert bb section in this forum
this is the log readed with CFP
any one can help me what is the wrong ???? Quote:
RIM Wireless Device Command-Line Programmer Version 3.9.0.49
Copyright 2008 Research In Motion Limited
Connecting to Bootrom: Connected
[ Uploading RAM Image 0x1801DC30 ] [############## 100 ##############]
Bootrom Version: 5.2.13.1
Hardware ID: 0x84000B03 RIM 8700 Series Colour GPRS Handheld
Supported Bands: 0x000F
Metrics Version: 4.7
Build Date: Dec 09 2005
Build Time: 07:57:52
Build User: cjames
Security: Enabled
Drivers: 0x00000002
External MCT/HWV: Disabled
HWV:
Board Revision 0001 - 0x0A
CPU Version 0002 - 0xC4
SW Compatibility 0003 - 0x03
Board Sub-revision 0004 - 0x0A
Power Mgt Hardware 0007 - 0x10
Mem Config Table (ver 1.7) (bootrom default):
Flash Chip: 0x80000000-0x803FFFFF Chip 0, Sub 0
Flash Chip: 0x84000000-0x8407FFFF Chip 0, Sub 1
Flash Chip: 0x04000000-0x05FFFFFF Chip 0, Sub 2
Flash Chip: 0x08000000-0x09FFFFFF Chip 1, Sub 0
OS Fixed: 0x80020000-0x8034FFFF Size 3264kB
FS Fixed: 0x04020000-0x05FFFFFF Virt 131072, Phys 131072, Sectors 25
5
FS Fixed: 0x08000000-0x09FDFFFF Virt 131072, Phys 131072, Sectors 25
5
OS NV: 0x80350000-0x8038FFFF Virt 65536, Phys 65536, Sectors 4
Branding: 0x80390000-0x803AFFFF
AppStore: 0x803B0000-0x803FFFFF Phys 65536, Sectors 5
DSP OS: 0x84000000-0x8407FFFF
CRC: 0x0212674B
Mem Config Table (ver 1.14) (actual):
FS Fixed: 0x04220000-0x05FFFFFF Virt 131072, Phys 131072, Sectors 23
9
OS Extended: 0x04020000-0x0421FFFF
5
HWV Entry: 0012 - 0005
CRC: 0x66B7A7E3
Flash:
Number of chips: 4
Flash ID: 0x88270089 (0x80000000-0x803FFFFF)
Flash ID: 0x88270189 (0x84000000-0x8407FFFF)
Flash ID: 0x88100089 (0x04000000-0x05FFFFFF)
Flash ID: 0x880D0089 (0x08000000-0x09FFFFFF)
Total Size: 68.5 MB
Memory Map:
Flash Range:
RAM Base: 0xA0000000
IRAM Base: 0x18000000
OS Address: 0x80020000-0x803239F3
File System:
Memory Map:
Sectors: 494
Branding:
VendorID: 1
OS Version: 2.3.0.76
Supported Bands: 0x0000FFFF
Metrics Version: 3.15
FS Code Version: 10.0.0.0
FAT Code Version: 2.4
Package Version: "2.3.0.76"
Build Date: Mar 12 2007
Build Time: 23:51:05
Build User: absadmin
SV Number: 26
App Start: 0x801A8E08
RAM usage: 0xA0000000-0xA0354380
IRAM End: 0x1805FF00
DSP ROM2 Address: *not present*
OS Extended Addr: 0x00000000
LDR Blocks: 0x80187B24
API Checksum: 0x00000000
JumpTable (<3): 0x8018657C
JumpTable (>2): 0x8018795C
Radio Code: Orpheus radio code linked
OS API Version: 70.0
STP Protocol Ver: 5.18.4 (release OS)
HWV:
Board Revision 0001 - [0x09 - 0xFF], 0x01
Board Sub-revision 0004 - [0x00 - 0xFF], 0x01
CPU Version 0002 - [0xC3 - 0xFF], 0x01
SW Compatibility 0003 - [0x00 - 0x03], 0x01
Power Mgt Hardware 0007 - [0x10 - 0xFF], 0x01
Version Table:
FAT FS Version: 2.4
STP protocol version: 5.18.4
BlockFS API Version: 10.0.0.0
USB driver version: 01.06
Kernel Version: 1.6.0.70
Metrics Version: 1.1
Build Time: 22:40:14
Build User: SCM
App:
Version: 4.2.1.91
Metrics Version: 1.5
Build Date: Mar 13 2007
Build Time: 00:00:28
Build User: RIM
Memory Map: 0x801A8E08-0x8032393F
App c_main: 0x802A3D8C
JumpTable (<3): 0x00000000
JumpTable (>2): 0x00000000
AppFSVersion: 2.0.0.0
RAM Map: 0xA035435C-0xA0354380
IRAM Map: Unused
App Type: unknown (0)
DSPOS Version: 2.3.0.76
Metrics Version: 1.4
DSP OS Address: 0x84000000-0x8405EF0B
Overflow code: 0x00000000-0x00000000
Overlay Table: 0x00000000
LDR Blocks: 0x00000000
Build Time: 22:38:08
Build User: SCM
Done.
