Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > BlackBerry (RIM)
BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs.
Old 02-24-2010, 06:37   #1 (permalink)
delower10's Avatar
Member: 890592
Sonork: 100.1581951
Thanks Meter: 4,418
Arrow FAQ : JL_Cmder
What is JL_Cmder?
JL_Cmder stands for JavaLoader Commander. JavaLoader is a command line tool provided by BlackBerry. JL_Cmder simplifies accessing the most commonly used JavaLoader commands.
Are there any system requirements?
Yes. You must install BlackBerry Desktop Manager or BlackBerry USB and Modem Drivers. Download DM5 Resume Supported link
What can JL_Cmder do?
Below is a brief overview of the available commands.
  1. deviceinfo - Displays information about the handheld.
  2. eventlog - Retrives and displays the handheld event log.
  3. screenshot - Takes a picture of the handheld screen. (OS 4.0.2+ required)
  4. wipe - Erases the handheld OS. Not really, but that is the simpleist way to explain it. After using the "wipe" command the device will be completely inoperative until the OS is reinstalled. (Error 507 will be displayed on the device)
  5. resettofactory - Removes the IT Policy from the device and wipes the device of personal data while leaving the OS installed and usable. (OS 4.3+ required).
NOTE: If you want to use an unlisted JavaLoader command select Command-Line Usage from the menu. This will display JavaLoader help information including syntax and all available commands.
Installation Instructions
  1. Download JL_Cmder V1.9.1.zip
  2. Extract executable.
  3. Double-click on executable.
    Vista Users: Right-click on executable and select Run As Administrator.
NOTE: Do NOT use JL_Cmder to "wipe" your device if you are just wanting to wipe your personal data from the device and leave it as it was out of the box. If you use the "wipe handheld" option in JL_Cmder your device will be rendered useless (Error 507) until you reload the entire OS. If you just want to wipe your personal data but leave the OS you can use the "wipe handheld" in the Options >Security Options >General Settings Menu on your device or, if your device has OS 4.3 or higher, use the "resettofactory" command in JL_Cmder. The only difference between the "wipe handheld" in the Security Options on the device and "resettofactory" in JL_Cmder is that "resettofactory" also removes the IT policy on 4.3 and higher OS devices.
Do NOT use JL_Cmder to wipe your device if your device is working fine and are simply attempting to upgrade your OS and you can't get the OS to load or be recognized by Desktop Manager or Loader.exe. Doing so will most likely render your device useless until you find the root cause of why the OS will not load to the device. Generally, this is caused by not deleting the vendor.xml file(s) or USB issues with the PC.
Download the JL_Cmder v1.9.0
Download the JL_Cmder v1.9.0 installer
Download : Blackberry Firmware Latest Released !!!
The Following 27 Users Say Thank You to delower10 For This Useful Post:
Old 02-24-2010, 07:00   #2 (permalink)
breakfruit's Avatar
Member: 1170297
Sonork: \m/(-_o)\m/
Thanks Meter: 36
Thanks dude! always like That!
The Following 2 Users Say Thank You to breakfruit For This Useful Post:
Old 11-06-2014, 13:19   #3 (permalink)
Member: 1241196
Sonork: 100.1660453
Thanks Meter: 4
Thanks master
i understand it, if we wipe the device and want to reinstall os what the best process to reinstall the os at blackberry`s
thanks you so much
[FAQ]: how to creat an Account in GsmFreeShop AMINOS GsmFreeShop-SERVER 14 05-12-2009 16:36
[NEWS] FAQ : How to log Alcatel C701/c820/c825 in GsmFreeShop Server AMINOS GsmFreeShop-SERVER 0 02-21-2008 11:30
PolarBox Faqs :-) wendigo PolarBox 1 0 06-09-2005 18:24
Page generated in 0.23913 seconds with 8 queries
