Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > BlackBerry (RIM)
BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs.
Old 12-16-2009, 05:03   #1 (permalink)
vinay_sharma's Avatar
Member: 309398
Sonork: 100.1590052
Thanks Meter: 5,455
What the Blackberry LED Indicator Lights Mean
Here is a quick guide to understanding the LED indicators of your BlackBerry.
Blue LED - The Blue LED on a Blackberry is for Blue tooth. A flashing blue light indicates an active connection via Bluetooth. You can Enable/disable this indicator under Applications > Options > Bluetooth > Menu > Options > LED Connection Indicator: On/Off.
Green LED- The Green LED on the Blackberry is for coverage indicator. If it is blinking then it means you are in a service area. You can enable/disable this "feature" under Applications > Options > Screen/Keyboard > LED Coverage Indicator On/Off.
Red LED- The flashing red LED indicates a new message is waiting. Go to your message folder and check for any unread messages. You can choose to be notified of new messages visually under Applications > Profiles > Advanced > [Select profile you wish to modify] > [Select message type you wish to modify] > Repeat Notification LED Flashing/Off
If you are using the Blackberry Storm, Sound is is used in place of Profiles.
Yellow LED- The flashing Yellow LED indicates that you are running out of battery. Time to get your Blackberry on the charger.
Best Regards
vinay_sharma
The Following 2 Users Say Thank You to vinay_sharma For This Useful Post:
Old 12-16-2009, 19:53   #2 (permalink)
alberht's Avatar
Member: 63988
Thanks Meter: 100
If you're posting anything that you've not written then write a source. Original at Blackberry-Repair.net.
What the heck does enter NCK mean? paulk451 Philips 6 03-26-2014 10:14
LED Indicator Light Bulbs 1156-382 Ba15s - Red IPMART ipmart WebShop 0 07-23-2009 22:50
Lighting about BB9000 led indicator ankywong BlackBerry (RIM) 4 05-13-2009 23:48
what is the pm faultage indication ? kiriazy Griffin 0 02-25-2005 20:37
What the detail meaning of the T28 channel info? subaru Old Ericsson Phones & Sony Phones 2 11-15-2003 07:05
Page generated in 0.14802 seconds with 9 queries
